Code help - Defender Source
Old December 13th, 2010, 08:29 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Code help
Got 48 stepper motor code. Truck has high idle. Cleaned it and soaked it in PB and it functions properly now. Still have 48 and high idle. Got the truck really, really wet recently. Ideas?
Thanks!
And hay
And I love you too
Old December 14th, 2010, 10:01 AM
huck1974's Avatar
huck1974
shane cates
94 d90
Update. Check engine light is on. No more 48 code. No codes at all. Idles at 2000 rpms.
And hay
And I love you too
Old December 14th, 2010, 10:14 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Tried resetting the computer, to see if the code stays cleared now?
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 14th, 2010, 11:23 AM
huck1974's Avatar
huck1974
shane cates
94 d90
Yes. Reset it a few times. I manually backed out the stepper motor until I got the desired rpms. The truck runs perfect now. Still has check engine light and code 48. Had the intake off to do injectors recently. Could a small air leak or vacuum leak throw a code 48?
And hay
And I love you too
Old December 14th, 2010, 11:26 AM
61rover's Avatar
61rover
John Crouse
Can you give a little more detail about adjusting the stepper motor? I think I have the same probem.
J.P.
Old December 14th, 2010, 12:44 PM
Hans's Avatar
Hans
Hans Haase
It's always possible that some kind of air/vacuum leak can cause it, if it's throwing the RPM's out of what enough. From the stuff I've found, it throws the code 48 under either of two conditions.
1: RPM below 500 with the stepper fully open.
2: RPM above 750 with the stepper fully closed.
-Hans
My oil line fix
Old December 14th, 2010, 01:00 PM
huck1974's Avatar
huck1974
shane cates
94 d90
J.P.
You can take the motor out and screw it in or out and it affects the idle. Now you know as much as me which is very little. lol
------ Follow up post added December 14th, 2010 12:02 PM ------
-Hans
number 2 is my problem. On top of that, I manually closed the idle crew all the way and there is no change to the way it runs. That should kill the motor. Must be vacuum or air leak to manifold....correct? Damn i wished I was smarter about this shit.
And hay
And I love you too
Old December 14th, 2010, 01:17 PM
Hans's Avatar
Hans
Hans Haase
That's what I'm thinking as well. The biggest potential leaks are in the intake tube between the MAF and the plenum. Thank goodness there aren't THAT many lines to check. Don't forget the normally-missed stuff such as the brake booster line.
-Hans
My oil line fix
Old December 14th, 2010, 01:55 PM
huck1974's Avatar
huck1974
shane cates
94 d90
-Hans
soaked everything down with a squirt bottle while running. It didn't kill the motor. No leaks.
I'll keep trying to figure it out. Your response has been much appreciated.
And hay
And I love you too
Old December 14th, 2010, 02:19 PM
The stepper motor has absolutely nothing to do with idle, except to say that it keeps the engine from dying when you decelerate to an idle from speed. You can't really "adjust" it cuz the ECU runs it in and out as it sees fit.
You get high idle when there is a problem with a sensor. Something is giving the ECU bad info. Check for bad vacuum hoses first, check your T fitting, be sure the diz and timing didn't get moved some how.
Old December 14th, 2010, 06:21 PM
huck1974's Avatar
huck1974
shane cates
94 d90
I checked everything you said and did a wet down to see if anything changed. It must be a sensor. Any guess as to how to chase that down?
I understand that the ECU runs the stepper motor but if I pull it out and give it a turn one way or the other, it is the only way I'm getting much of an idle adjustment right now.
Can the sensor to the charcoal canister have anything to do with the idle or code 48? I got rid of it a few weeks ago because I didn't want to replace the rotten lines and it has no real use.
And hay
And I love you too
Old December 15th, 2010, 05:33 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Got everything fixed. Thanks for your help
And hay
And I love you too
Old December 15th, 2010, 05:42 PM
What was it? Did it fix itself (have had that happen many times)?
Old December 15th, 2010, 05:50 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Replacement stepper motor was bad also. Got one at the auto parts store from a 93 Chevy Astro van for $42. It fixed everything. I spent half a week over thinking the entire situation to realize I was stupid and it was what the computer said it was in the first place. I think I'll have a beer and try and kick my own ass now.
And hay
And I love you too
Code 17 Question loved90 Defender Technical Discussions 3 December 22nd, 2011 05:14 PM
yet another radio code question GliderKing Defender Technical Discussions 3 June 4th, 2005 05:06 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
D90 Stock Cassette Deck Security Code? Erik Defender Technical Discussions 4 December 9th, 2004 06:56 AM
