Code 88 - Defender Source
Old April 4th, 2004, 10:28 PM
COSteve
Steven Reed
93 Defender 110 - #107
Question Code 88
New to the board, had my Check Engine light go on with 88. Checked the book and it says "#88 Purge Valve Leak". Looked in the Shop Manual and I know what it looks like. Checked the truck and no apparent leaks. Then tried the reset procedure and it does not clear. So...... is it "usually" the valve itself, or should I start going through all the lines with bubble solution? 93 NAS 110 with 91K Thanks to all in advance!
Old April 5th, 2004, 09:53 AM
http://www.rangie.com/files/167_382.jpg
From here
http://www.rangie.com/articles_topic...at=7&subCat=51
Also sometimes Faults can be caused by bad connections to sensors.
Old April 5th, 2004, 05:04 PM
COSteve
Steven Reed
Code 88 - Purge Valve
Mike, Thanks for the post. The 88 code has specifically a "leak" parameter, so it would not be affecting the sensors (o2). Am I missing something?
COSteve
Old April 5th, 2004, 05:39 PM
What I mean is, the wires running to the sensors can become disconnected, and then the computer would show a code saying something is wrong. So just fallow the cable going to the sensor back to the ECM and make sure that nothing is unplugged or cut.
Old April 6th, 2004, 09:01 PM
COSteve
Steven Reed
Flipped the Master Switch
I flipped the master and reset the box and the 88 code cleared. May be intermittent. Have to reset the stereo station presets now
Old April 7th, 2004, 10:14 AM
You don't have to pull the batt.
From the FAQ section
Clearing the display:
1. Switch ignition on.
2. Disconnect serial link mating plug, wait 5 seconds, then reconnect.
3. Switch ignition off, wait for main relay to drop out.
4. Switch ignition on. The display should now be reset. If there are other faults, the next one will be displayed. Otherwise the display will be black
5. If there is more than one fault repeat steps 1 to 4, to clear each fault until the display is blank.
Old April 7th, 2004, 12:32 PM
COSteve
Steven Reed
Michael, Tried that and it did not clear, but will try again should it still be a recurring issue. Thx Steve
Old April 7th, 2004, 01:07 PM
You can also just pull off the main plug on the ECM with the engine off that way you don't loose your radio, that or I have a wire that goes from the radio to the Batt so when I disconnect everything else The radio will still be connected.
Old May 19th, 2016, 02:42 PM
jperakis
James Perakis
94 ST
resurrecting this old thread.
Driving to work this morning the CEL came on.
I checked the code next to the ECU and its a code 88 - purge valve leak.
WTF - Looks like the part if it needs to be replaced is an arm and a leg. Any thoughts on what I can do to troubleshoot?
Thanks all!
remember two things...
Code 17 Question loved90 Defender Technical Discussions 3 December 22nd, 2011 05:14 PM
yet another radio code question GliderKing Defender Technical Discussions 3 June 4th, 2005 05:06 PM
Fault Code 19 chrisvonc Defender Technical Discussions 17 April 29th, 2005 05:28 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
