Code 68(vehicle speed sensor input fault) - Defender Source
Old August 11th, 2016, 05:38 PM
cascade90's Avatar
cascade90
Mason Worley
'95/NAS D90 SW #59/500
This is on my '95 NAS D 90. I have replaced all the gauges with VDO units. They all work great! The speedo is working nuts on. My issue with this is I'm getting this code. I'll clear and after say 20 miles the CEL comes back on. My question to you all is what can I look at this point? One other other bit of info is I'm using the YBE100540 speed sensor. I also have the 120 ohm resistor in line. Any and all input will surely be welcomed.
Help needed!! Vehicle speed sensor Crash303 Defender Technical Discussions 23 April 7th, 2016 04:44 PM
Fault Code #26 Doug Defender Technical Discussions 8 July 10th, 2013 09:54 AM
Speed sensor code 68 with no symptoms jhhorse Defender Technical Discussions 0 November 20th, 2011 08:03 PM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 06:02 AM
Fault Code Misfire on #6 cylinder dbwitt Defender Technical Discussions 2 February 16th, 2004 09:30 PM
