Code 48 - Stepper Motor - Idle control - fix - Defender Source
Old January 6th, 2014, 06:59 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
The stepper motor is the idle speed control device that is screwed into the left rear of the intake plenum - as you face the engine. I removed it and briefly sprayed carb cleaner into the business side of it - past the seat and spring. This was followed up by setting it on end and spraying it full of WD40, letting it sit for a bit. After refitting it with a makeshift gasket and a few drops of blue-medium- Locktite, short of the first start-up, it has worked flawlessly….knock on wood.
I believe that little bugger cost approximately $150.00!
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old January 6th, 2014, 07:22 PM
The Dro
Dro
1988 Ninety
You can buy it for a lot less.
Go to Autozone and look for this: Duralast AC102. It's $55.
ID:	87449   Click image for larger version
Old January 7th, 2014, 08:26 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Has anybody else used this stepper motor?
Old January 7th, 2014, 08:53 PM
Grover's Avatar
Grover
I bought a stepper motor from pep boys for $15
Same stepper as used on the Chevy astrovan.
Old January 7th, 2014, 09:52 PM
the range rover has one from autozone, idles fines when it warms up. d90 is still on its factory stepper at 88k
idle, motor
How to adjust AC151 stepper motor/idle control? wicks Defender Technical Discussions 5 September 21st, 2010 12:33 AM
Idle Control Valve (idle stepper motor) fleabus For Sale - Parts 3 June 28th, 2009 12:13 AM
Code 48 Stepper motor devinchi Defender Technical Discussions 8 September 8th, 2005 05:43 PM
dirty stepper??? ttegt Defender Technical Discussions 1 March 31st, 2004 10:37 PM
