Code 48 Stepper motor - Defender Source
Old August 23rd, 2005, 08:02 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
Ok, so on the trip home with my new to me 95 D90 I got a check engine light, after checking the code reader it showed a code 48, stepper motor.
SO can I safely drive it with this issue?? All it does is adjust the idle, right?? Any tip on fixing it without replacement?
Thanks in advance for any help.
Old August 23rd, 2005, 09:26 PM
" SO can I safely drive it with this issue?? All it does is adjust the idle, right?? Any tip on fixing it without replacement?"
Safe to drive. Yes, you can clean it. That sometimes fixes it.
Old September 8th, 2005, 10:13 AM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
Ok, so after cleaning the stepper a few times, and resetting the codes (battery disconnect, code reader disconnect, then battery re-conn, reader re-conn.) and still getting a 48, I got a new genuine stepper, and still have the code.
So now I am trying to find the tests, and adjustments outlined here.....
check base idle speed- see setting procedure. Refer to tests 15 and 16 of continuity test procedure. Check road speed sensor- refer to test 25 of continuity test procedure.
I havn't been able to find them in the .PDF manual I have.
Old September 8th, 2005, 10:18 AM
Add this baby to your favorites!
http://www.rangie.com/articles_topic...at=6&subCat=26
Old September 8th, 2005, 11:22 AM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
thanks, bookmarked!
Old September 8th, 2005, 01:37 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Did you do the reset procedure again after installing the new stepper? Otherwise, it may take awhile before it goes away 'on it's own'. I had this happen..
Old September 8th, 2005, 02:24 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
I did a reset, and got the 02 code for "reset computer" and then got the 48 back in a few miles.
Old September 8th, 2005, 03:01 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
If the stepper and it's wiring is good, than you've narrowed it down a lot.
Either your idle speed is out of the accepted range (700 +/- 50 I think)
Or the VSS, or it's wiring, is no good. The VSS is mounted down by the transfer case inline with the speedometer cable.
-Hans
My oil line fix
My 100k stopped odometer fix
Old September 8th, 2005, 05:43 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Also check the housing that the IACV is screwed into...they will come loose from the plenum and cause an air leak and code 48.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
motor
Installing a Napa Stepper Motor p# 2-1738 Heath Defender Technical Discussions 0 January 13th, 2005 10:04 AM
Stepper motor same on RR? waveridin1959 Defender Technical Discussions 15 December 16th, 2004 10:52 AM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
stepper motor erik d Defender Technical Discussions 2 February 11th, 2004 04:09 AM
