Code 48: Base Idle Speed? - Defender Source
Old April 29th, 2005, 05:31 PM
thug1313's Avatar
thug1313
Brian Ellis
Sold it!
Question Code 48: Base Idle Speed?
Already searched everyhting about Code 48...I know it means replacing the stepper motor. I put in a new one 2 weeks ago, code went away. Since then, I took off the plenum, did some work in there and now the code is back. I keep trying to reset the code, but it keeps coming back on. I noticed there was a thing in FAQ about setting Base Idle Speed.
The manual gives steps for setting Base Idle Speed. Anybody ever do this? Should I attempt it by drilling out the tamper plug on the plenum and follow the steps in the book? After warming up the engine I'm idling at about 750 RPM. The setting (without throttle cable) should be 525 +/- 25 RPM, right?
Just confused......
Brian Ellis
Old April 29th, 2005, 10:24 PM
Do the procedure. The cap should pop out no drilling. If you are anal you can buy a new plug at the dealer.
Old April 29th, 2005, 11:52 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Actually, it might also be the vehicle speed sensor which is another input for the Idle Stepper motor.
-Hans
My oil line fix
My 100k stopped odometer fix
idle
1997 D-90 Idle Speed ndhlp Defender Technical Discussions 4 October 11th, 2006 11:43 AM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Code 48 Stepper motor devinchi Defender Technical Discussions 8 September 8th, 2005 05:43 PM
Fault Code Help howellm70 Defender Technical Discussions 1 January 30th, 2005 05:43 PM
