Code 19 - Defender Source
Old October 25th, 2011, 08:34 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Code 19
Was driving my temperamental companion, as I down shifted on highway up a hill (she's not the most aggressive on hills) she fired a check engine mayday...... code 19 'Throttle Position Sensor' I have yet to do any research, so this is the lazy start to research..... has anyone suffered from a 'code 19'?
Have to mention, she had actually been driving good for a change, other than the occasional at warm up she would 'misfire' or lose idle. Only on certain occasions while she warmed up, after that she been burning gas normal.....
thanks ahead
cheers
Old October 26th, 2011, 08:45 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Anyone familiar with the 'Throttle Position Sensor' where it is or how to test it?
Old October 26th, 2011, 08:56 AM
It's a little black plastic piece on the front side of the intake plenum (directly opposite where the throttle cable attaches). It has two screws holding it on, and wires coming out of it.
I am not sure about testing it other than remove it and clean it thoroughly and make sure the shaft turns freely and springs back.
hth
charles
Originally Posted by pendy
I'm here for the D's
Old October 26th, 2011, 11:25 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Thanks Charles, I'm going to take it off, clean it and see if that will do..... I do have a idle issue going on and maybe all related....
hth
charles
Old October 26th, 2011, 11:49 AM
You can move it and it should be electrically a clean sweep with no dead spots. I can't remember the specs on what you use on the test meter to check.
Ron
Old October 26th, 2011, 11:58 AM
Check for pin holes in the tube that goes from the MAF to the intake as well.
Old October 26th, 2011, 05:07 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Will check all recommended, clean it and see if leaks. If change is last option what is the part you change out of these 2? or do both need to be changed? they both go by same name.....
Name:	Screen shot 2011-10-26 at 5.04.01 PM.png
Old October 26th, 2011, 05:25 PM
The first one is the one you have but you don't want to buy that new from RN at that price
I am sure there are better new options, otherwise just get a used one from one of the used parts vendors.
Old October 26th, 2011, 05:39 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
damn was afraid it would be that one..... will exhaust other options before...... any recommends on used parts movers?? thanks again..... great info!
Old October 26th, 2011, 05:43 PM
Try Randy Williams (pushngo here). He's in PA so nearby.
http://britishboneyard.com/
Old October 26th, 2011, 05:46 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Rockauto has it for $190..... damn...... recognize it now. I've actually taken it off before to clean when I've had intermittent idle issues and the stepper motor. The idle issue seems to come & go. Possible other make that would fit?
------ Follow up post added October 26th, 2011 05:47 PM ------
Thanks!!
Code 48 Stepper motor devinchi Defender Technical Discussions 8 September 8th, 2005 05:43 PM
yet another radio code question GliderKing Defender Technical Discussions 3 June 4th, 2005 05:06 PM
Fault Code 19 chrisvonc Defender Technical Discussions 17 April 29th, 2005 05:28 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
