Code 17 - Throttle Position Sensor - Defender Source
Old August 25th, 2015, 11:14 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
My 94' NAS is throwing code 17 intermittently but I haven't attempted to troubleshoot yet. Assuming the throttle position sensor is bad, where is the best place to source one? Stay with Lucas or is generic okay?
$180 shipped here from "lrparts": Land Rover Discovery 1 Range Classic Defender Throttle Position Sensor ETC8495 | eBay
Is "lrparts" Lucky8?
Old August 25th, 2015, 02:07 PM
Don't assume it's bad. Test it first. It could just be corrosion on the connectors.
Old August 25th, 2015, 02:46 PM
down_shift's Avatar
down_shift
Russell
Not to worry, I will sort out the issue before dropping ~ $200 on a nonreturnable part. Sort of fast tracking sourcing the part to move on it should it come to this route.
Old August 25th, 2015, 03:53 PM
They usually get flat spots. So you have to test throughout the whole range. Common failure item around 100k plus.
Old August 31st, 2015, 09:02 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
I'm also having a recurring TPS fault. I can check for clean connectors but couldn't find a test procedure for the TPS in the manual. Can you tell me how to test it? Is it simply a continuity test across the full range of motion or what?
Old August 31st, 2015, 09:10 AM
down_shift's Avatar
down_shift
Russell
The attached is 93' RRC Multiport Fuel Injection Electrical Troubleshooting Manual. This should be of help. Look at Test G. I haven't looked at my Defender work shop manual yet. Will scan the applicable pages and post here in the next few days. Thinking the TPS test will be the same.
File Type: pdf 93 Range Rover Electrical Troubleshooting Manual.pdf (1.18 MB, 46 views)
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
For a RRC but should be the same...
Old August 31st, 2015, 09:27 AM
Connect you multi meter ( set to 20v DC ) between the ground ( battery -ve ) and pin 20 on the back of the ecu ( you'll need to remove the cover ).
you should see it start around 0.3 v and max around 5v. The progression should be smooth over the full travel of the throttle pedal. If you see any spikes or out of sequence values it would indicate a 'worn out spot' and cause for replacement.
An old fashioned analog meter is best for this test or something like a fluke that has a digital bar graph 'needle'
Old August 31st, 2015, 09:43 AM
slorocco
Dan Prasada-Rao
Perfect! Thanks guys.
sensor
Throttle Position Sensor Source?? rgrrvr Defender Technical Discussions 34 April 10th, 2013 09:56 PM
Throttle Position Sensor (TPS) Duke D90 Wanted 0 April 3rd, 2010 05:15 PM
TPS - Throttle Position Sensor for 1997 D90 #ERR4278 pcscharfe For Sale - Parts 11 August 27th, 2009 02:31 PM
Idle problem - Throttle position sensor? JBfoot Defender Technical Discussions 20 January 7th, 2008 11:45 AM
Throttle position sensor chrisvonc Wanted 0 April 24th, 2005 05:57 PM
