Code 17 Question - Defender Source
Old October 2nd, 2005, 10:50 AM
loved90's Avatar
loved90
Jay Love
Code 17 Question
Code 17 pop up, which is the throttle potentiometer. Truck still runs perfect, but is this something that is just going to go out all of a sudden? Should I be worried? Check engine came on and stayed on once the code popped up. Thanks
Old October 2nd, 2005, 11:48 AM
First I would reset the ECU and wait to see if the code comes back, then check the TPS, here is the test sheet.
http://www.rangie.com/articles_topic...at=6&subCat=26
The TPS is easy to replace and not all that exspensive either if you need a new one.
Old December 22nd, 2011, 04:57 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
Does anyone by chance have an updated link to this link?
Old December 22nd, 2011, 05:14 PM
LRFAQ still has them I believe.
yet another radio code question GliderKing Defender Technical Discussions 3 June 4th, 2005 05:06 PM
Error Code 17? Quimbola Defender Technical Discussions 1 December 9th, 2004 11:04 AM
Check Engine light, code 17 mchombeau Defender Technical Discussions 3 March 17th, 2004 06:12 PM
