Code 14- Coolant Sensor 1995 D-90 - Defender Source
Old September 11th, 2010, 10:14 AM
JPerkins
James Perkins
1995 Defender 90
My 95 D-90 has a code 14-Coolant Sensor. I have looked up the code and this is what it says:
Code 14- Coolant sensor
Usually indicates a bad fuel injection coolant sensor. May also indicate a bad engine thermostat or a stuck viscous fan clutch. Refer to test 14, continuity test procedure.
Any help anyone could give me on how to fix this problem would be greatly appreciated.
Old September 11th, 2010, 10:47 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Does the temp look good in the dashboard gauge (uses a different sensor), if you're not overheating and the temp shows ok on the gauge, then you just need to replace the coolant sensor for the CPU.
It's toward the front of the intake manifold, behind the alternator, and threads into the intake from the top-down.
-Hans
My oil line fix
My 100k stopped odometer fix
Old September 12th, 2010, 08:16 AM
JPerkins
James Perkins
1995 Defender 90
Thanks for your advice. I will order a new replacement sensor. Thankfully I am not having any overheating problems. I did have the engine loose power several times when it was extremely hot outside. The RPM's dropped to 200 and the engine just sputtered. The next morning it started up and ran like nothing was wrong. It did not trigger the Check Engine light until a couple of weeks later. I hope this is all related.
Thanks again.
Jim
Old September 13th, 2010, 11:48 AM
Sounds like the temp sensor to me.
If you have a stuck open thermostat, the temp guage will not stay at the proper temp which will throw the temp sensor code. That is the easist way to tell between the two issues.
1995, 90, 95, coolant, d-90, sensor
Radio Code Help? ;) wicks Defender Technical Discussions 7 December 31st, 2009 07:59 AM
Code 48 Stepper motor devinchi Defender Technical Discussions 8 September 8th, 2005 05:43 PM
yet another radio code question GliderKing Defender Technical Discussions 3 June 4th, 2005 05:06 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
