Code 12 - MAF Mass air flow - Defender Source
Old August 3rd, 2006, 05:14 PM
Antonios
Antonios Hadjigeorgalis
No more
I got a code 12 today, which is the MAF. on this site, http://www.robisonservice.com/servic...ouble.asp#1990 it says that the code could be due to a bad connector.
I pulled the plug off and the unit has 5 tabs, while the plug only had connections for 4. Is this how it is supposed to be?
I tested the voltage back in March and it was within spec. Is that the only way to test the unit to make sure it needs replacing?
Miami, FL
Old August 3rd, 2006, 05:57 PM
robisonservice
John Robison
2008 Supercharged Range Rover
The wires are power, ground, reference, and signal return. What you can do is connect to the signal wire and measure the voltage as you speed up the motor. It should increase smoothly as the motor speeds up. If it drops out or moves jumpily the air meter is bad.
Old August 3rd, 2006, 06:01 PM
Antonios
No more
When I tested the voltage I measured it at the ecu. Which one is the signal wire in the plug?
Thanks for the information.
Miami, FL
Old August 6th, 2006, 06:58 PM
Antonios
No more
Why would the code reset? After the check engine engine light came on and the code 12 was thrown the truck was running OK. yesterday I had to drive it and when I started the truck the check engine light went off by itself without me resetting it. As I started out on a 40 minute drive I had to stop twice as the engine (although still running) wouldn't produce any power. When I pulled over and disengaged the clutch the engine stalled. After waiting for the relay to drop out it started back up fine. When it happened a second time within 10 minutes I disconnected the MAF and then it drove fine for the rest of the night.
Miami, FL
Wanted: Mass Air Flow (MAF) Sensor for 3.9L D90 dbj2003 Wanted 5 May 7th, 2009 02:31 PM
Rebuilt air flow meters MAF only $160 Antonios Misc. Chit-Chat 9 March 9th, 2006 10:06 PM
Mass air flow sensor! TwisteD90 Wanted 1 October 20th, 2005 06:50 PM
