Clutch wont disengage - Defender Source
Old March 23rd, 2013, 06:36 PM
gonzanc's Avatar
gonzanc
Nick
'95 4.2L NAS D90
Just changed the clutch master cylinder and the slave cylinder and now the clutch won't disengage for reverse or second. I adjusted the clutch master cylinder as per the manual.
Also, the brake lights are constantly on now. Any ideas?
Old March 23rd, 2013, 08:04 PM
Is the pedal firm throughout the whole stroke?
Old March 23rd, 2013, 10:25 PM
gonzanc's Avatar
gonzanc
Nick
'95 4.2L NAS D90
Ok. It fixes itself apparently. I know the adjustments were spot on according to the manual, so I figured it had to do with the slave. I bled the system with a motive power bleeder and same issue. Turns out pumping the clutch 10-15 times solved the problem. Odd
Also, the brake lights was the switch on the back if the servo. It came loose. A quick tightening solved the problem
clutch
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
