Clutch will not engage fully - Defender Source
Old December 21st, 2012, 10:43 AM
Hbmike's Avatar
Hbmike
Mike Stuart
Defender90 1994
I replaced the clutch master cylinder and bleed the lines.
The clutch will only engage on the left half and not the right half.
No problem when the engine is turned off.
The clutch paddle is a little lower than normal.
How far should the clutch panel be lower than the brake pedal for proper adjustment?
I
Old December 27th, 2012, 10:07 PM
Hbmike's Avatar
Hbmike
Mike Stuart
Defender90 1994
Hi guys, I found that a clutch tapered pin had dis-engaged after the transmission was pulled.This was preventing shifting on the right side of the clutch pattern.
What do you think caused the clutch pin to dis-engage?
Any help would be appreciated
Thx
clutch
Clutch does not engage - do I need to bleed? sro Defender Technical Discussions 18 January 2nd, 2013 11:28 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
