Clutch/Transmission Problem - Defender Source
Old August 10th, 2007, 06:41 PM
mlw911
Michael Walter
1995 D90 ST
Hello all. Got a strange problem I cannot seem to figure out. Had the engine re done which entailed dropping the transmission and clutch. While out I had the clutch replaced. When I first got the car back the thing shifted so easily - like a dream.
After a couple of weeks it felt very stiff and notchy. I took it back assuming so leaking of clutch/transmission fluid but the mechanic said everything looked good. What else could it be? It was so smooth now it's gone. When the tranny was out I did see a white/greasy looking substance all over the place which seemed odd but he cleaned it up before assembling.
Thoughts?
Old August 10th, 2007, 07:38 PM
Have you checked the fluid level in the gearbox. Might as refill it with some REDLINE MTL. DOnt trust your mechanic
Old August 11th, 2007, 07:08 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Could also be a leaky master cylinder. I think they all leak at one point or another.
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 11th, 2007, 07:50 PM
you have no idea. what about the slave cylinder. that one seems to go a little more undetected.
Old August 12th, 2007, 09:26 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
Those clutches aren't easy to bleed out properly. On several occasions I have seen the master and slave go out after removal and reinstall of tranny. If you replace one, do the other!!!
Where does the clutch catch??? If the clutch ingages low on the pedal motion then you can adjust the clutch pedal rod that is attached to the clutch master cylinder
Old August 15th, 2007, 08:17 PM
mlw911
Michael Walter
1995 D90 ST
Problem is not with the clutch engagment. I should have been clearer. The action of moving the shifter through the gears is what is notchy and kinda rough. Right after clutch/tranny install it was very easy to slide into gear and move around. Now not so much. It's almost like it was from being drowed in in some super slick gear lube to shifting without none. The wrench cheched the levels and they were fine.
clutch, transmission
Help! Problem starting (95 SW) reaper99999 Defender Technical Discussions 8 March 2nd, 2006 07:22 PM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
