Clutch throw out bearing - Defender Source
Old November 20th, 2015, 08:02 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Looking for some opinions on clutch release bearings. Fitting a R380 to a 4.6 powered 110, and having seen an occasional post about bearing failures, wanted to hear what's what.
Email is
Same place, new dogs.
Old November 20th, 2015, 08:06 AM
I've seen the plastic ones melt. The aluminum-bodiesd ones seems like a good solution to that.
Aside from that, the Britpart plastic one I put in my truck 5 years ago is still working great.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old November 20th, 2015, 08:21 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Trevor, the guys at Independent in Chevy Chase recommended stick with genuine. The plastic they believe melts due to drivers riding the clutch improperly. Turn that flywheel!
Old November 20th, 2015, 08:55 AM
Megasquirt for V8 engines - Off-road products
Old November 20th, 2015, 09:17 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Trevor, we have the heavy duty metal version in stock... give me a call if you want it.
Old November 20th, 2015, 09:18 AM
Roverlab
Trevor Griffiths
Megasquirt makes sense. Anybody have any experience with their release bearing set-up?
Email is
Old November 20th, 2015, 09:30 AM
That's exactly why they melt - because the plastic TOB wasn't designed to be engaged continuously.
It happens to those folks who keep the clutch pushed in at stop lights as well
Old November 20th, 2015, 09:41 AM
Oddly enough, I've only ever seen throw out bearings fail in Land Rovers, and never a clutch. I've always put Genuine ones in whenever I do it.
Old November 20th, 2015, 09:50 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I used an HD on my rebuild. 50k miles later, clutch is fine, bearing is out. I have my plastic brand new one and I still am hesitant to use it. My new clutch just arrived as there is no sense in not replacing it too as the real cost for me is the time and energy to crack everything open. I am light on clutches, always driven stick-- sometimes they just go out. Friggin annoying.
Old November 20th, 2015, 10:39 AM
1of40's Avatar
1of40
1of40
Can anyone explain why a HD bearing is better?
Trevor, FYI, the Disco R380's parts I believe are different than the Defender R380 so just make sure you have the right parts.
Old November 20th, 2015, 10:47 AM
The stock bearing housing is plastic. The plastic wears out where the slipper pads contact it. It can also overheat and melt as discussed above. The HD versions use a metal housing.
Old November 20th, 2015, 10:51 AM
Still need a reliable source and PN for the HD TOB.
The only one I've seen is an aftermarket unit with PNFTC5200HD
Old November 20th, 2015, 10:57 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
That's the one.
Old November 20th, 2015, 10:59 AM
???? Everyone sells them. What exactly are you asking?
There are two options. The Aluminum body one that most sell. They are made by Rakeway. Flywheel & Clutch Kits
And the plated steel version made by Megasquirt. Linked above.
Short Unit (UTJ100210): Defender 1983-2006, All late 300TDi, Wolf XD, 2.5 Petrol, NA Diesel - Current Part Number UTJ100210 or the older, and now superceeded number FTC4177
Long Unit (FTC5200): ALL V8s, 200 300TD1s with LT77 Gearboxes, Defenders Pre 1986, 200 + 300 Inc TD5, Disco 1 1989-1998, Disco 2 1998-2004 Inc. TD5, V8s Range Rover P38 95>, 101 V8 Forward Control, Land Rover Series 3 inc stage 1 V8. Current Part No is FTC5200. (Previous superceeded numbers being 594272, GRB229, FRC4679, FRC9568.)
clutch
replacing throw out bearing jayz Defender Technical Discussions 18 April 27th, 2017 11:14 PM
throw out bearing and fork; Free jayz For Sale - Parts 2 May 28th, 2012 06:20 AM
Throw Out Bearing Fork bjf Defender Technical Discussions 13 January 29th, 2012 07:50 PM
Throw out bearing staple, are we suppost to glue it in? Neil McCauley Defender Technical Discussions 4 August 31st, 2010 09:21 PM
Just replaced clutch; throw out bearing rattle Noah Defender Technical Discussions 7 August 29th, 2006 04:23 PM
