Clutch stuck to floor - Page 2 - Defender Source
Old April 1st, 2010, 05:59 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Originally Posted by Neil McCauley View Post
Yes, the more you do it (replacing master/slave) the better and easier it gets for you.
X2. The second time I did it was much easier.
- Charles Eames
Old April 1st, 2010, 08:24 PM
huck1974's Avatar
huck1974
shane cates
94 d90
First and only time was not that hard. You guys scared me into thinking it was a job.
And hay
And I love you too
Old April 2nd, 2010, 12:21 AM
bd90
94 Arles Blue #1644
Ordered the slave cylinder, soft line, and clutch pedal spring from George (RDS) today. After explaining the symptoms he immediately suggested the Master cylinder was the culprit. But I'll try the easiest and cheapest first and see what's involved with a MC replacement and maybe order that in the near future (MC @ $100 w/ shipping).
RN has clutch master cylinder fluid and it's DOT 4. I've been topping off with DOT 3. I could swear the MC Cap said use DOT 3. What's right?
Old April 2nd, 2010, 06:52 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
If you've been using DOT3 fluid you'd better replace the whole system (get that master cyl). You must use the DOT 4 or better synthetic, preferably Castrol GTLMA or lucas. Other fluids will contaminate the rubber parts and they will fail (swell and turn to mush) Flush the hard line out. You don't want any of the DOT3 fluid in there.
Matt Browne
Old April 4th, 2010, 08:33 AM
bd90
94 Arles Blue #1644
Found fluid leaking down the clutch pedal so I guess its official....MC is bad. Guess I'll call George and order it Monday. It was dumb not to order it with the Slave and soft line. WIshful thinking I guess.
Old April 4th, 2010, 10:17 AM
berti1554
Robert Klima
84/110
Why did I tell to replace all? (I started the same way)
Flush the line before you put in the new parts. Otherwise you might get the same problem because of small debris being in the line...
clutch
Clutch pedal sticks to floor, then starts popping up as the truck gets warmer. Quimbola Defender Technical Discussions 7 December 30th, 2008 04:43 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
Clutch pedal to floor MARKGOLDSMITH Defender Technical Discussions 6 October 30th, 2006 06:18 AM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
