Clutch Squeak - Defender Source
Old August 13th, 2009, 07:44 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Clutch Squeak
I have a rather annoying squeak that comes from the clutch pedal every time I press it in and out. Coincidentally, I also hear a distant squeak coming from the clutch area too when I press in the clutch.
Is there as easy fix for this?
Thanks in advance,
Greg
Old August 13th, 2009, 09:51 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I don't know about a squeak, but mine had a squeal. Turned out it was the carrier for the release bearing spinning on the tube that houses the input shaft. I had shredded bakelite all over the interior of the bellhousing. I guess it was good that is wasn't a cast iron carrier like some Series Rovers have.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 13th, 2009, 10:09 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Originally Posted by JSBriggs
Is it the pedal arm squeaking on the pedal tower? Maybe a drop of teflon lube (triflow) on the pivot.
-Jeff
That solved mine.
Old August 13th, 2009, 02:22 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Yep, it is right on top of the pedal. I will spray some lubrication up there. Make sense, we'll see how it works. Thanks guys.
Old August 13th, 2009, 02:24 PM
Does your have a zerk fitting on the pivot? Somewhere I have a series pedal that does and mine is squeaking on my 90 and I have to figure out how to fit a zerk to it too.
Old August 27th, 2009, 10:59 AM
DonFromWhitby
Don Andrews
'94 NAS D90 #CDN-80, 2011 LR4
Mine was squeaking from the torsion spring right on the pedal... sprayed some teflon on it - no more squeak..
Old August 27th, 2009, 11:18 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Mine is squeking fierce as well - I sprayed whatever lube I could find on the workshop but didn't quiet it too much - will try some teflon next.
clutch
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
