Clutch spring MOD--MUST HAVE - Defender Source
Old July 2nd, 2005, 11:47 PM
I have added a second clutch return spring to the pedal. The way the current set up is with the butterfly, the take up is uneven, also, there is a tendency for the clutch not to come all the way back up.
What I did was take a series clutch and brake return spring bracket, cut it in half [so it only uses the two top bolts that hold the clutch pedal assembly on--as oppsed to the top two on the brake as well] and put on a new clutch return spring ($1.50 per at Roversdownsouth).
Huge difference. Much firmer. Best 30minute mod yet. Only downside is you cannot keep the stock cardboard trim. You could use series III trim I suppose if you had to have trim down there.
Ron
PS of course I still have to replace my slave cylinder.
Old July 3rd, 2005, 11:17 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Pics? I don't have a manual, but sounds pretty cool. Pics?
EwS
Old July 3rd, 2005, 10:03 PM
I will get them for tuesday.
BTW it says you have a 97 in your sig--no clutch on a 97
clutch, mod
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
» Defender Registry
94 D-90
jkins
Rubicon
Sharmin
Add your Defender
