Clutch Slave Master Fluid Mystery - Defender Source
Old August 11th, 2010, 12:17 PM
RickM
Rick Mabus
95 D-90 ST
Alright. I need some feedback from you guys who are much wiser than me. Few weeks ago I noticed a ton of fluid on the floor of my garage. In an attempt to see what it was I started to refill everything. Nothing looked low. Friday my clutch all the sudden dropped a ton and I started guessing that is where the fluid came from. Took it in to a shop Monday and they said everything looked good in the slave and master and they could see now weeping/leaking. They kept it overnight to even double check and still none of the indicators that the cylinders were bad came up. I then remembered when I went to replace my clutch fluid the cap for my clutch was worn and cracked. If pressure in a hydro system is important then could a bad cap cause a sporadic fluid leak/clutch to feel bad? I am not seeping fluid right now. When it looses fluid it dumps it quickly etc.
The shop checked the air and drained and refilled the lines and put me back on the road hoping to see if something else might be a culprit. It had been about 7 years since I had drained cleaned out the system by the way. I will look forward to your thoughts.
Old August 11th, 2010, 04:13 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
There is a rubber hose inline with the steel lines which connects to the slave cylinder below, this was a problem for me in the past...it is easier to spot this hose looking from under the D90 towards the top.
Old August 11th, 2010, 06:19 PM
RickM
Rick Mabus
95 D-90 ST
So was that hose burping intermitantly or was it simply leaking constantly?
clutch, master, slave
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Mystery of the disappearing clutch fluid Trigger Defender Technical Discussions 4 January 5th, 2009 05:50 PM
Clutch Master, Slave & hose sale @ BP Neil McCauley Misc. Chit-Chat 0 September 22nd, 2006 07:11 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
