Clutch Slave Cylinder - Tips for loosening bleeder - Defender Source
Old April 14th, 2016, 06:29 PM
LRColorado
1990 Defender (200 TDI)
1990 110 200 TDI
I can't for the life of me get enough room to get the torque needed to loosen the clutch slave cylinder's bleeder. I have been soaking it the last couple days thinking that would help in the cramped space, but cant get enough room/leverage to break it free.
I know members of this forum will have some tips and tricks.
Thanks for your help.
Old April 14th, 2016, 06:35 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Take if off so you can remove the bleeder on the workbench. Then reinstall and bleed - it does not take too long (on my 94 NAS anyway). One lesson learned, if in doubt, replace it. If it begins to leak it puts brake fluid on the clutch.
Angus
Old April 14th, 2016, 06:43 PM
If you remove it, replace it with a factory unit. Cry once, buy once.
1/4" ratchet and socket. Won't take much before it breaks.
Old April 14th, 2016, 06:57 PM
LRColorado
So should I order a new slave because I am going to bet I break it off. If I should order a new slave what else should be done? Like to place just one order for parts.
Old April 14th, 2016, 07:01 PM
I would order new master, slave and lines if it was me.
Old April 14th, 2016, 08:33 PM
LRColorado
Never replaced clutch or brake line? Is it fairly easy or is it an art form?
Old April 14th, 2016, 08:42 PM
Super easy and self evident when you remove the old with the MC and SC.
Old April 14th, 2016, 08:49 PM
I would not say super easy. If it is LHD, the master is a fair bit of work. With the 4 cylinders the down pipe needs to come out for the slave and that can be a pain especially if it is the big one piece unit.
Old April 14th, 2016, 09:01 PM
He was asking about replacing the lines John and yes it is super easy. They are plug and play. As for the master on a LHD you unbolt the brake master from the bulkhead and nudge it out of the way and the clutch master can be wiggled out.
Old April 14th, 2016, 10:43 PM
LRColorado
It is a 110 RHD 200 TDi
------ Follow up post added April 14th, 2016 08:47 PM ------
What brands are considered genuine land rover? I read i should get genuine parts.
Old April 14th, 2016, 10:52 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
1/4" ratchet---as John said. Never broken one, but I don't know how tight yours is this that isn't gospel... I use a ratchet to loosen mine if they are tight. Striped too many brake fittings and such now I use a brake line wrench and a 1/4" ratchet when tight.
Old April 14th, 2016, 11:02 PM
LRColorado
I have gotten the rachet on the bleeder but there is not enough room to get leverage to break it loose. Do you also remove the slave to get the bleeder off? Seems like the top nut to the slave will be hard to get to.
Old April 14th, 2016, 11:06 PM
OEM was Girling, now under the great TRW agglomeration. OEM is what you want. It does not need to be genuine. Genuine is the same part at 5 times the price.
Old April 14th, 2016, 11:08 PM
To get the slave out, it is best to remove the exhaust down pipe first, IMO. Then you have clear access.
Old April 28th, 2016, 05:40 PM
LRColorado
Update: Was able to get the bleeder loose without removing any other parts. Just had to adjust how I approached the task of getting my hand up into the tight space. Used a socket to break it free and an open ended wrench to bleed. Flushed out all the old fluid and now the clutch works great.
Thanks for all the advice.
bleed, clutch, slave
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
clutch slave cylinder lordhelemt Defender Technical Discussions 4 May 9th, 2013 07:23 AM
clutch slave cylinder. CavemanDiesel Defender Technical Discussions 4 December 27th, 2012 10:39 AM
Clutch slave cylinder new in box for defender jonathon For Sale - Parts 2 December 3rd, 2012 10:42 PM
Clutch Slave cylinder bleed?? Quimbola Defender Technical Discussions 2 February 10th, 2009 11:17 PM
