Clutch Slave cylinder bleed?? - Defender Source
Old February 10th, 2009, 06:55 PM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
Allright clutch pedal is mushy. Need to bleed the slave, what and where am I looking?
I topped off the master, but I can't find the bleed screw?
Any help would be much appreciated.
-Josh
Old February 10th, 2009, 09:27 PM
This is a 110, but you're looking at basically the same thing. The bleeder is above the hose, so access isn't as good as it could be. This is the drivers side (and obviously) just above the exhaust. Hopefully yours isn't as crappy as this one.
Name:	DSCF1532 - Resized.jpg
Old February 10th, 2009, 11:17 PM
Quimbola's Avatar
Quimbola
Josh
Thank you!!
Thank you for the pic. No WAY I would have found it with out it. It was way farther away from the master than I would have guessed. Clutch is happy again!
bleed, clutch, slave
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Clutch Master, Slave & hose sale @ BP Neil McCauley Misc. Chit-Chat 0 September 22nd, 2006 07:11 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
» Defender Registry
110
clb1994
D90 #2326
DM2326
Add your Defender
