clutch slave cylinder. - Defender Source
Old December 24th, 2012, 12:57 PM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
Clutch was leaking, bought both master and slave ctlinder. Master went on with no problem. Slave cylinder is giving me problems. The threads are a different size. Any advice would be nice. The one on the right came off the d90: one on the left is replacement
Eric
Old December 24th, 2012, 01:07 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Do you mean the thread for the flex hose? Take the hose out to be sure, it's only 2 nuts, so you can try to mate them outside the truck with good light and space to work on. May be the threads are dirty or damaged. Where did you get your replacement slave cylinder?
- Charles Eames
Old December 24th, 2012, 01:17 PM
CavemanDiesel
Eric Smirh
1985 D90
The threads in the holes on the left side of the slave cylinders in the picture are a different size. I think I bought it from Atlantic British.
Old December 24th, 2012, 04:42 PM
Threads will be either 10mm or 7/16th-20, depending. If the 10mm isn't fitting, then you have the other. Send it back and be sure that the send you a metric one. If you don't then you have to replace everything all the way to the MC.
Old December 27th, 2012, 10:39 AM
CavemanDiesel
Eric Smirh
1985 D90
Thank you o2,
I did not know that there were 2 different parts, got the new one in today and it looks right. All is good in Rover land today.
clutch, slave
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch slave cylinder new in box for defender jonathon For Sale - Parts 2 December 3rd, 2012 10:42 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Clutch Slave cylinder bleed?? Quimbola Defender Technical Discussions 2 February 10th, 2009 11:17 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
