clutch series - Defender Source
Old October 27th, 2008, 01:10 PM
wertz=rover
gary wertz
1975 Series III
clutch series
looking for clutch input diameter. not sure if it is 1 1/8" or 1/16" diameter. need to know so I can look at different clutch, gearbox and tranfer case, engine combinations. looked over the web and could not get a straight answer. any help would be great.
G.Wertz
Omaha Ne
Old October 27th, 2008, 07:11 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
Are you looking for the the measurement at the clutch disk centre, at the splines? I checked a series 9.5 inch clutch plate and it was 1.125.
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old October 27th, 2008, 10:18 PM
wertz=rover
gary wertz
1975 Series III
rover gearbox
sweet. did the math and that equals 1 1/8". I did the research and found a clutch from a mustang 2 might work. also found that the sm420 or the sm465 has the same shaft size. Now just need to double check the input shaft stub lenght. I show that the rover has a 6 1/2 lenght from tip to housing. this should be the same as the sm gearbox that I am looking for.
G.Wertz
Omaha Ne
clutch, series
clutch series 3 wertz=rover Misc. Chit-Chat 0 October 27th, 2008 11:19 AM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
