Clutch Reservoir Cap - Defender Source
Old January 25th, 2006, 07:49 PM
texasdefender110's Avatar
texasdefender110
T.J. D...
NAS Defender 110
I have a 1993 NAS Defender 110.
The clutch reservoir is in an awkward location. I am having a difficult time grasping the cap.
Any tips for removing the cap?
Does the cap unscrew or pull off?
--T.J.
Fightin' Texas Aggie Class of 1998, Whoop!
Old January 25th, 2006, 07:57 PM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
it unscrews. if it is really stuck just remove the hood to get better access. I used chanell locks to get it going.
Insert pithy quote here.
Old January 26th, 2006, 10:00 AM
texasdefender110
T.J. D...
NAS Defender 110
Channel Locks worked. Just needed a little more force.
There was a bit of gunk around the lip of the reservoir, which wiped off easily. The fluid level was fine and the rubber gasket on the inside of the cap was fine.
Thanks for the tip Read.
--T.J.
clutch
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
