clutch question slave or master holding pressure - Defender Source
Old April 30th, 2012, 06:21 PM
aka rover's Avatar
aka rover
ed angel
95 D90
This is a 85 110 with the LT85 5 SPD, what its doing is building pressure during normal driving. As you drive it the clutch starts getting closer to the top of the pedal. I can crawl under the truck and open the bleeder and it will be under pressure squirt fluid out like your bleeding the brakes. I can then get back in and it shifts normal for about 8 to 10 times and then slowly starts buiding pressure with every shift. I was thinking it was the master cylinder not allowing the fluid to return to resivoir. as the there is no leaks and the slave is in bleeder up and hold pressure.
Anyone else experiance this one? Should I just pull the master on clutch and see if there is somthing clogging it? It has a stainless hose and no rubber in the line so im pretty sure its not the line restricting it.
Thansk Ed
85 D110 3.5 3 DR
Old April 30th, 2012, 08:34 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Jeff
Thanks that was it the rod was adjusted way to tight! kinda a pain in the arse to get to and adjust but its done and working great
Thanks Ed
85 D110 3.5 3 DR
clutch, master, slave
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Clutch Pressure Plate Question bstraw Series Technical Discussions 4 November 30th, 2010 02:44 PM
Clutch Slave Master Fluid Mystery RickM Defender Technical Discussions 2 August 11th, 2010 06:19 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
