Clutch problem. Need advice - Defender Source
Old June 16th, 2016, 11:48 PM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
My clutch petal goes all the way to the floor and does not come back up.
It has been acting funny for a couple of weeks. Sometimes it goes about 1 inch from the floor before working and then it will return to about half way.
I added fluid two days ago and that helped. But today I get in the rover to take a drive and it goes all the way to floor. I have not seen any fluid on the ground, but it must be losing fluid when I'm driving. So, what do I need to replace? Slave or Master or both? 300 tdi with r380.
Old June 17th, 2016, 12:19 AM
Naplm00
Matthew
All the way to the floor with no return usually indicates master,it may be leaking into the bulkhead.
I'd still replace both and make sure to lube the pin end on the slave. Master is fiddly to get to but slave is easy. Both should be bench bled before install.
On a more destructive note, they could both be good and the release fork could have punched through at the center pivot. You would have most likely felt and heard this tho... Start with the easy stuff. Trevor @ rovahfarm should have everything
Problem changing steering ball joint RHD 110-advice appreciated flananuts Defender Technical Discussions 5 May 11th, 2014 07:31 PM
Clutch/Transmission Problem mlw911 Defender Technical Discussions 5 August 15th, 2007 08:17 PM
Clutch problem Capt Milks Defender Technical Discussions 0 February 11th, 2007 09:49 AM
Idle problem - need advice fleabus Defender Technical Discussions 24 February 7th, 2006 06:36 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
