Clutch problem - Defender Source
Old February 11th, 2007, 09:49 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Clutch problem
My clutch stoped working the other day. All the sudden while driving I couldnt shift gears. I could use the Rpm's and slide it into gear to get home but the clutch wouldn't disingage. My first thought was to replace the slave cylinder since my fluid level was OK and I saw no leaking at the master cylinder. Well I replaced the slave cylinder however that didn't fix the problem. When I bleed the lines I do get fluid to pump down to the slave cylinder and the petal feels normal.
When I take off the slave cylinder I notice the ram only sticks out about an inch from the mounting flange at the bell housing. Does anybody know if this is normal or should it stick out farther?
clutch
clutch problem diagnosis help... bharris Defender Technical Discussions 18 November 14th, 2011 04:42 PM
odd clutch problem tomaco1 Defender Technical Discussions 1 November 29th, 2009 07:20 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
