Clutch pedal sticks to floor, then starts popping up as the truck gets warmer. - Defender Source
Old December 30th, 2008, 10:42 AM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
I read all of the other Clutch issue threads.
Mine seems a bit different, when it is cold outside i get the problem, but when the truck gets warmer the pedal starts popping up.
Does this still seem like my MC or SC?
Thank you.
Old December 30th, 2008, 10:49 AM
Overland90's Avatar
Overland90
95/D90 #169; Aston Martin
Is there any clutch fluid residue on the pedal arm inside of the cab? If so, it is time to replace the MC.
Old December 30th, 2008, 10:56 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Wash your floor man!
Old December 30th, 2008, 11:17 AM
Quimbola's Avatar
Quimbola
Josh
There is zero residue.
Old December 30th, 2008, 11:41 AM
Start with the obvious: Is the spring broken or really weak?
I had this issue on my series and the spring was shot completely. I figured that out after I bought it a new MC.
Old December 30th, 2008, 11:55 AM
Quimbola's Avatar
Quimbola
Josh
I'll check the spring, that could be the culprit. How could I tell if it is "weak"?
Old December 30th, 2008, 12:51 PM
Is it springy? Seriously it is pretty obvious if it is dead. On series trucks you can install the wrong spring (there are two ways springs mounted) and if you do it over stretches it and it does not last long.
ONce you take the spring off you will be able to see if the pedal moves up and down freely or if it is sticking because of a bad MC/SC or maybe because the joint where the pedal moves in the box is seized.
Ron
Old December 30th, 2008, 04:43 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
I had that problem this past fall, except I also has fluid on the pedal and floor. And yes it was the master cylinder. Had it replaced and have had no problems since.
clutch, start
AC compressor clutch squeal artm Defender Technical Discussions 9 June 14th, 2010 04:34 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
clutch for 95 d90 w/ 4.6 vesparover Defender Technical Discussions 7 January 4th, 2006 11:09 AM
Clutch Pedal Rubber Dfndr90 Defender Technical Discussions 9 September 2nd, 2004 12:00 AM
clutch jperakis Defender Technical Discussions 2 March 19th, 2004 06:23 PM
