Clutch pedal sticks halfway - Defender Source
Old May 4th, 2016, 12:46 AM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
After driving for about 30 minutes my clutch pedal will stick halfway back on the return.
Pressure is good and reservoir is full. The fluid is slightly dark though. I can pull up on the pedal with my toe and the pedal flicks back in place. It is weird that it is sporadic and usually after 30 mins of driving.
Would this be a return spring or something internal. I am not seeing any leaks. Last two times the slave cylinder went out it leaked on my foot.
With a full reservoir I don't think anything is leaking.
Old May 4th, 2016, 01:25 AM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
I'd have a look at the master cylinder. It could leak to behind the piston but not to the outside, so it acts like a shock absorber.
I'm for the Russian pencil
Old June 8th, 2016, 01:07 PM
Craigd's Avatar
Craigd
Craig Dickson
Just wanted to update on the culprit for my clutch pedal. Turns out the bolts on the master cylinder were loose.
clutch
Defender Hood Sticks Up CDeWan Defender Technical Discussions 6 November 16th, 2012 11:42 AM
110 cab, 3/4 tilt and sticks FS atlcruiser The Vendors Loft 0 June 14th, 2012 12:24 AM
Instructions for fitting HOOD sticks, mounts, etc.? wicks Defender Technical Discussions 15 January 25th, 2009 12:36 PM
Clutch pedal sticks to floor, then starts popping up as the truck gets warmer. Quimbola Defender Technical Discussions 7 December 30th, 2008 04:43 PM
Hood sticks and top for 90? wicks Defender Technical Discussions 15 October 20th, 2008 10:59 PM
