clutch pedal locks up - Defender Source
Old June 18th, 2011, 04:57 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
What can you do on the road if you clutch pedal locks up?
Old June 18th, 2011, 05:05 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Match your revs? You can shift without it. That's assuming it's locked engaged
Old June 18th, 2011, 05:06 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Try and fix it??
Is it the pedal that's gone wrong or has the slave cylinder push rod punched through the clutch operating fork?
If it's the latter then you need a new clutch fork and while the engine and transmission are split you may as well throw in a new clutch too.
A tow truck might help to get you home
Mike Hammond
Old June 18th, 2011, 05:17 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
The clutch pedal won't move at all. If I crack the line on top of the clutch master the pedal will go down. As soon as I tighten it, it locks back up.
Old June 18th, 2011, 05:53 PM
mikeslandrover
Mike Hammond
What happens if you crack the bleed nipple on the slave cylinder?
Mike Hammond
Old June 18th, 2011, 06:10 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Im gonna try that in the am.
Thanks.
It really seems the slave is locked up.
Old June 18th, 2011, 06:22 PM
mikeslandrover
Mike Hammond
Or pull the slave cylinder and see what's occurring.
What sort of milage does the clutch have on it?
My bet is still on the fork or the spring plate breaking up
Good luck.
Hope you get home OK.
Mike Hammond
Old June 18th, 2011, 06:57 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Good call,
The rod that goes to the fork is much further into the tyranny than it was on my other truck. It doesn't seem to floating around in there, its just further in.
The clutch has less than 20k on it, but I didn't change the fork on it, luckily I did on the one in my 110
Old June 19th, 2011, 04:01 AM
mikeslandrover
Mike Hammond
Thanks, I always change all the components that go with the clutch - pressure plate, friction plate, release bearing and release fork, they all have a finite life and don't last much longer than the fiction plate.
I once ( as a penniless youth) opted to change only the friction plate. You guessed it - a few thousand miles later I was in there again for the pressure plate.
You can reinforce the release fork by welding flat bar across the fork to support the point that the clutch rod pushes on. That's the point yours will have failed at.
Mike Hammond
Old June 19th, 2011, 08:55 AM
Make sure you reinforce the fork. You don't want to do it again. Another good upgrade is the aluminum housing for the release bearing.
Old June 19th, 2011, 01:43 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Can I just drop the tyranny? Or is it easier to just pull the whole engine.
Tempted to have it done in a shop, a bit afraid of the price though.
------ Follow up post added June 19th, 2011 02:01 PM ------
where do u get the aluminium housing for the release bearing? I saw one included in a britpart HD kit, but I read those kits were for shit.
Originally Posted by Red90 View Post
Make sure you reinforce thei fork. You don't want to do it again. Another good upgrade is the aluminum housing for the release bearing.
Old June 19th, 2011, 02:57 PM
mikeslandrover
Mike Hammond
I believe you can pull the engine forward about 6" if you take the rad shroud and fan off. That apparently gives just enough space to do the job. So a mechanic friend told me. Failing that I'd pull the engine. Luckily or not, I've not had a clutch fail on it's own. I tend to put a new clutch in when it's all apart for something else such as a gearbox or transfer box or a full rebuild.
Mike Hammond
Old June 19th, 2011, 05:14 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Are you certain it's not the slave cylinder? I have heard a few people have had problems with new ones seizing.
Old June 19th, 2011, 05:26 PM
mikeslandrover
Mike Hammond
I think it's diagnosed as a failed clutch actuating fork. Not good but it happens.
There are ways of preventing it happening either by strengthening it or putting a new one in when the clutch is changed.
Tom can you pull the push rod out from the bell housing and maybe look in to confirm that it is indeed the fork that's failed?
Are you going to change all the clutch components while its all apart?
Mike Hammond
Old June 19th, 2011, 05:34 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Probably, it sucks because it only has about 20k on it.
Old June 19th, 2011, 05:50 PM
kevkon's Avatar
kevkon
kevin
If the fork failed, why does the slave rod not move? I would have thought the clutch pedal would go to the floor.
Old June 19th, 2011, 06:09 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I think the slave was all the way out and bound up.
Old June 19th, 2011, 06:33 PM
No it extends all the way and the pedal is hard as a rock. Been there, done that got the T-shirt.
------ Follow up post added June 19th, 2011 04:39 PM ------
Without a lift, the engine is easiest. With a lift, then the tranny.
Do it yourself. It is very easy with this engine. 4 hour job with a friend. 5 to 6 hours by yourself. No special tools needed. I just did the same thing in October on my truck, so I'm speaking first hand here.
Oh, and make sure it in an OEM clutch fork and then put a backing plate on. The OEM ones are actually made with hard steel. If you really do not want to see it again, run in a grease line.
Old June 19th, 2011, 07:58 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I can get it on a lift at school, so I may just drop the tranny. Should I replace the less than 20k clutch?
Old June 19th, 2011, 08:18 PM
I wouldn't.
clutch
is there a clutch pedal adjustment for 95 d 90? rickauf Defender Technical Discussions 6 May 21st, 2008 02:56 PM
Clutch Pedal Sticking whitelandy Defender Technical Discussions 8 October 8th, 2004 10:23 AM
Clutch Pedal Rubber Dfndr90 Defender Technical Discussions 9 September 2nd, 2004 12:00 AM
Sticky Clutch Pedal JimC Defender Technical Discussions 11 March 11th, 2004 01:44 PM
