clutch pedal locks up - Page 2 - Defender Source
Old June 19th, 2011, 09:27 PM
Rover clutches are good for at least 100k if you do not abuse them.
Old June 20th, 2011, 02:31 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I would, 20K is maybe 1/5 or more worn. Depends if you plan on keeping the truck for another 100,000 miles
Mike Hammond
Old June 20th, 2011, 04:41 PM
paulnb57
Paul Beckwith
92 D90 300tdi hard top rebuild
Its a no brainer to me - you have all the hassle of either removing the engine or the box, seems false economy not to change the clutch pack and release bearing while you are in there............my fitter replaces the clutch by removing the tunnel and gear stick/transfer lever, undoing all the bell housing bolts and the gearbox rubber mountings then supports the gearbox on cradle/trolley and slides the whole lot back, having just enough room to change the clutch etc...........Ive only seen it done on tdi's though........
Paul
Ede Bibe Lude Post mortem nulla voluptas.
Eat Drink Play, After death there is no pleasure.
Old June 20th, 2011, 05:36 PM
I suppose that depends on the user.... Some people get 500 k out of a clutch, some 50 k.
Old June 20th, 2011, 06:53 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Is it terrible to tow the 65 miles home using a front wheel dolly? I have one, and it would save me about $200 from the towing.
Old June 20th, 2011, 07:38 PM
Can you rent a Uhaul flatbed for cheaper?
Old June 20th, 2011, 08:08 PM
Just take off the rear driveshaft.
Old June 27th, 2011, 08:51 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Good call Mike! Clutch fork was shot!
Got the engine out in a couple hours, I took the Rad out but probably could of done it without. I haven't gotten it back together because I decided to have the clutch fork reinforced, I'll try and reassemble tomorrow.
The ball that the fork pivots on was a bit rough, so I just sanded it a bit and it seems good.
Thoughts?
My new Starter, very shiny. Burnt out the old one bumping the truck on the trailer.
I also got the rebuilt injection pump in
The manual calls for molybdenum disulfide grease for the pivot and other things in the fork area, I got some but it says its for the brakes? What should I use?
ID:	39959   Click image for larger version
Old June 28th, 2011, 07:22 PM
mikeslandrover
Mike Hammond
I'd probably put in a new push rod too, if it's rough it's going to cause friction and wear. I'd recommend copper based grease on the push rod end, the forks sometimes come with a blob of the stuff on them.
Mike Hammond
clutch
is there a clutch pedal adjustment for 95 d 90? rickauf Defender Technical Discussions 6 May 21st, 2008 02:56 PM
Clutch Pedal Sticking whitelandy Defender Technical Discussions 8 October 8th, 2004 10:23 AM
Clutch Pedal Rubber Dfndr90 Defender Technical Discussions 9 September 2nd, 2004 12:00 AM
Sticky Clutch Pedal JimC Defender Technical Discussions 11 March 11th, 2004 01:44 PM
