Clutch pedal has no pressure - Defender Source
Old June 28th, 2010, 12:23 AM
ttegt's Avatar
ttegt
Thomas Tegtmeier
1995 Defender 90
I have been reading past threads and didn't see anything similar to my day, I used my 95 d-90 140 k miles to shuffle around a couple of trailed boats today. One boat heavy, one not so.... It was a couple of short moves, back and forth, slight grade, all went well, With no load, 1/4 mile in to trip home, tranfer case disengaged, I hit the lever to re engage it, while still rolling, not fast, but moving. It engaged feeling as I down shifted, pulled right over, now, no pressure at the clutch pedal. Fluid level is fine. engine runs fine, any ideas as to where I should begin?
Old June 28th, 2010, 12:29 AM
If you start it in first gear low, do you get forward progress? If so, it is probably a slave, master or clutch fork. If not, then it is a probably a problem with the actual clutch.
Old June 28th, 2010, 12:49 AM
ttegt's Avatar
ttegt
Thomas Tegtmeier
1995 Defender 90
Yes it bucks forward when engaging starter motor and in gear. Do you know how I would check the clutch fork? Thanks for your help
Old June 28th, 2010, 01:33 AM
I am not sure. You might be able to see it if you remove the inspection plate on the front of the transmission right behind the oil pan, but like I said, I don't know.
Old June 28th, 2010, 09:06 AM
ttegt's Avatar
ttegt
Thomas Tegtmeier
1995 Defender 90
clutch
is there a clutch pedal adjustment for 95 d 90? rickauf Defender Technical Discussions 6 May 21st, 2008 02:56 PM
Clutch Pedal Sticking whitelandy Defender Technical Discussions 8 October 8th, 2004 10:23 AM
Clutch Pedal Rubber Dfndr90 Defender Technical Discussions 9 September 2nd, 2004 12:00 AM
Sticky Clutch Pedal JimC Defender Technical Discussions 11 March 11th, 2004 01:44 PM
