clutch not engaging properly - Defender Source
Old September 8th, 2009, 07:42 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I have replaced a leaking clutch master & slave, but now after bleeding system the clutch pedal is not engaging without much effort, with the clutch pedal to the floor, I have tried to turn adjusting nut of the clutch master but this has not helped much.
Any thoughts?
Old September 8th, 2009, 08:43 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Do you mean disengaging? Just to make it clear. Your problem is when the clutch pedal is to the floor, the clutch hasn't fully disengaged?
Old September 8th, 2009, 10:53 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
That is correct Chris, my mistake for not being clear.
Old September 8th, 2009, 11:02 AM
The system is probably not fully bled. They can be difficult to bleed.
Old September 8th, 2009, 11:09 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I am assuming this started immediately upon changing clutch master and slave. I would bleed system again. If still have a problem, would pull slave and make sure that pressing clutch peddle makes slave move - then make sure the little clip is still on the release lever for the slave push rod to fit into(should be able to see it with a mirror and light).
Old September 8th, 2009, 11:16 AM
Bleed again and fit the big spring on the pedal.
Old September 8th, 2009, 01:07 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
will try bleeding again, thanks everyone...
Old September 14th, 2009, 05:08 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
As soon as I open the slave bleeder screw fluid gushes out.. is this normal? even before I push on the clutch pedal the fluid is already running out of the slave. This does not sound normal to me, maybe the Flexi hose is bad with a pin hole or something, any ideas.
Old September 14th, 2009, 05:21 PM
Normal. As long as you don't see bubbles it is bled properly. Try the big spring if you don't have it already. Is there the proper free play on the master?
Old September 14th, 2009, 05:28 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
The master has proper free play, thanks Ron. I can see this is a two person job...the unit does shift gears easily while the truck is turned off with the clutch pedal engaged...but a lotta good that helps.
Old September 14th, 2009, 05:42 PM
Did you bench bleed the MC before installing? Sometimes air gets trapped up there.
Old September 14th, 2009, 05:58 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
no I did not, but I will do everything again tonight with help..
Old September 14th, 2009, 06:50 PM
i just cursed myself having read this.
Old September 14th, 2009, 07:06 PM
mikeybob2@msn.com's Avatar
mikeybob2@msn.com
Michael Sabanovich
1994 Defender 90 #1880
What is the "big spring"? I think I must need one...
1994 D90 #1880
Old September 14th, 2009, 07:23 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
Keep bleeding... it will get better.
Old December 17th, 2009, 07:46 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I now have a similiar problem, the clip that holds the slave shaft is on the release lever but there seems to be alot of play in the release lever? It only seems to engage when I find the one good spot and releases as soon as I let it go.
Old December 17th, 2009, 10:39 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I checked again, the release lever itself seems very loose
Old December 19th, 2009, 10:58 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Mine worked fine after I bleed the system again, but now the flex hose has gone bad.
Here we go again, I had purchased it a while back & just saved it for such a day to come.
Any tips on getting the flexi off, it is a very tight spot to get too...any special brake tool to make life easier now???
Old December 19th, 2009, 03:46 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I just used 2 wrenches, I think a 15 and an 18, The bigger one on the flex hose itself. I also got some more room when I took out the intercooler hoses and side vent hose. It was tight though.
clutch
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
