Clutch "Moan" and not in the good way... - Defender Source
Old April 28th, 2010, 06:02 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
I have had a strange sound in the passenger compartment when I shift, on and off for the last 4 months, I don't remember if it was present when I first bought it but I can't be sure.
Its when I am coming into the friction zone after having the clutch engaged (so easing the clutch pedal out). It will moan/groan loudly in the cabin during that period, the only time it doesn't seem to do it is when I'm easing the clutch out at very low (1000-1500) RPM. To describe the sound its almost a mmmaaaaaaammmmppp then I'm off and running.
It definitely corresponds to when I feel like I've made a sub-par shift, and I thought it was worse when cold, but now I'm not sure. I haven't tried the "Car Talk" "clutch diagnostic" test of finding a big tree and putting it in fifth to see if it doesn't stall immediately.
I originally thought it was the MC or hydraulics, since I had a slow MC leak into the cabin when I bought it, but I replaced the MC and SC and its still there.
Does this sound familiar to anyone?
Old April 28th, 2010, 06:58 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I got a similiar problem, sounds like the TO bearing.
Robert Deniro
Old April 28th, 2010, 09:04 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Pardon my ignorance but what exactly is a TO bearing, and what was your repair process? Does this seem to be the consensus?
I'm glad to have the input, as it has stumped a few people
Old April 29th, 2010, 09:41 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
TO=Throwout Bearing--the clutch fork presses on it--it is on the input shaft of your transmission, basically, and presses against your clutch pressure plate. When it presses on the pressure plate, it "disconnects" the clutch from the flywheel by reducing the friction caused by the pressure plate. Not an expensive part, but not an easy replace procedure.
Old April 29th, 2010, 03:04 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Would the TO bearing cause more noise when I have the clutch fully depressed? Could it be a pilot bearing, as I've found a few accounts of others who replaced their TO bearing and still had the sound...
Should I put the t-case in neutral and try to recreate the sound by slipping the clutch to make sure it isn't somewhere else?
Does anyone know what exactly a dealer charges to do the job? I'm guessing at that point, I might as well get a clutch kit and have them do everything, anyone know how many "hours" this job would take the LR dealer?
Old April 29th, 2010, 03:33 PM
Neil McCauley
Neil McCauley
Since u got it all apart, change it anyway, also check the mainshaft and its splines for any damage as well as endfloat. Also don't forget the new staple for the TO bearing, in fact order all of those parts, they're all cheap. Look at the condition of the fork parts as well.
Robert Deniro
Old April 29th, 2010, 04:39 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Can't thank you all enough... It will just get markedly worse before it fails right?
And anyone know about labor costs?
Old April 29th, 2010, 11:03 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I strongly recommend to change the clutch fork. They fail with time.
- Charles Eames
clutch
