Clutch Master/Slave Issues - Page 2 - Defender Source
Old August 31st, 2013, 09:03 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Outcome?
Originally Posted by Jackie Treehorn View Post
An inspection later this evening will probably confirm that you are correct.
Did you resolve this issue?
What was the solution?
RDavisinVA
Old September 27th, 2013, 12:16 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
I'm a week late on replying to close the loop on this thread. Hopefully, this will provide some advice later on down the road for anyone experiencing similar issues.
Basically, the hydraulics were fine (worn and chaffed slave cylinder, but still servicable). THey (all hydraulics) were nonetheless replaced with new.
Okay, so as it turns out, one of the pivots/fulcrums of the clutch fork was damaged. The pivot pin had fallen out either from being forced or simply fell out, so that makes sense given the "feel" of the clutch when I originally described it as being able to half-depress the clutch. Anyway, it appears as though the throwout bearing had rotated itself 180 or so degrees and maybe that event is what damaged the clutch fork pivot. Hard to say really, but that was the problem.
While in there, it was also discovered that a small peice of the bellbousing (about the size of a quarter - the inner part of the thread/stud hole) had cracked and fallen into the inside of the bellhousing, so perhaps that debris caused something to grab in the trowout bearing. Again, hard to say because that small piece could have been sitting in there held to the inner wall of caked clutch material and oil.
Incidentally, the clutch fork end (where the pushrod sits) was not worn or damaged at all, yet the entire fork was replaced anyway.
So, the sum total of all of this is that we now have a new clutch, new master/slave, newly resurfaced flywheel, new rear main seal.....oh and new belhousing too.
Hopefully that brings closure to this issue and adds to the possibilities when any of you are diagnosing this type of issue. From a worst case scenario perspective, this was about as bad as it could get (clutch-wise). FAR MORE COMPLICATED THAN I HAD ORIGINALLY SPECULATED.
Many thanks to Robert and Bill and others for their input on this one.
Old September 27th, 2013, 04:13 PM
Can you post the rear main seal part # ? I need to do mine to stop the only leak I have on the 90.
95' D90 - daily driver..
Old September 27th, 2013, 08:55 PM
Jackie Treehorn
A
1985 (legitimately)
Sorry, don't have the P/N
You have a 300Tdi in a NAS 95? Nice
Old September 27th, 2013, 08:58 PM
no std V8 - missed the 300tdi part so i'll have to hunt it down
just call me observant
Old July 11th, 2016, 03:25 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Going to revive this thread... to post a fix i found.
I need to get a clutch line on my hybrid build to my r380 clutch slave
Clutch master has a 3/8-24 port. Very common brake fitting size. I'm using 3/16 hard line to take it from the clutch master to the trans tunnel (or just above).
Then i am use a 3/8-24 female to male adapter from pegasus racing, with a mount:
p/n LA45288 4AN Brake Fitting with Frame Tab, Weldable or Rivet Mount
To connect to a flex line:
p/n 4-21-S-90 21 inch Size 4 TFE Hose, Straight to 90 degree
Then to a male to male adapter that threads into the slave port:
p/n 3265-59 Male 12 x 1.0mm Metric Convex Seat to 4AN Male, Steel
My clutch slave has a 12x1.0mm port. This apparently is odd and not OEM. Probably b/c my slave is aftermarket. Also - i am using a crush washer as a seal since the port is very deep and no adapter I found is long enough to seal on the port seat. Per Pegasus racing the crush washer is a perfectly acceptable seal.
All in was $51 shipped. And the quality is probably much better than anything in a LR box.
Will post pics in my build thread when done. Hope this is helpful to some
clutch, master, slave
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 12:49 AM
Family trip delays, D90 having clutch issues Roverlab Misc. Chit-Chat 12 April 4th, 2013 08:51 PM
D'Oh clutch slip mikeslandrover Misc. Chit-Chat 40 July 27th, 2005 02:50 AM
Clutch spring MOD--MUST HAVE evilfij Defender Technical Discussions 2 July 3rd, 2005 09:03 PM
Clutch issues mspell Defender Technical Discussions 13 March 21st, 2005 10:45 PM
