Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest - Page 4 - Defender Source
Old December 4th, 2005, 08:58 PM
You might as well get new flex and hard lines too, they are cheap and ez to destroywhen removing. I learned that thehard way and had an extra week ofdowntime for it.
Old December 6th, 2005, 08:05 PM
mattarm's Avatar
mattarm
Matt
1993 D110
In the last day or two I have noticed fluid on the inside of the bulkhead, now (slowly) starting to appear on the drivers floormat. I have not noticed in perceptable change in steering, braking or the clutch. The fluid is relatively thin and brown in color. Am I looking down the barrel of a full fledge master/slave failure that will surely leave me high and dry at the worst possible moment, or do I have a little time? Can this only be the clutch or potentially brake or steering?
Matt
Old December 6th, 2005, 08:55 PM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
definetley not steering, the fluid is all down int he engine bay, and if the high pressure side goes, you will know it in a hurry. Most likely either clutch or brake. Watch the levels closely. Is either pedal becoming spoungy?
Pain is weakness leaving the body
Old December 7th, 2005, 02:00 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Often the fluid runs down the offending cylinder's pedal giving a strong clue as to which cylinder is ready to let go big time.
Clutch is inconvenient, brakes life threatening
Mike Hammond
Old December 7th, 2005, 11:09 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Jeff, at least change the rubber line while you are doing the other parts.. they dry rot over time. But i would do all the lines like stated above... just a few more $$ into the rover pit...lol
Legend in My Own Mind.
Old December 10th, 2005, 06:13 PM
mikeslandrover
Mike Hammond
My flex hoses have lasted the best part of 20 years
I'm just starting to swap them out now as the MOT inspection man starts to become unhappy about their condition.
Mike Hammond
Old December 10th, 2005, 06:37 PM
Neo
Jeffrey Rosbrugh
95 D90 ST #2585
Thanks Guys, will do. I am trying to get it back up and running pretty dependable as I bought the SIIa I was looking at a few months back. It is supposed to be loaded in Southampton on Monday, so, since I know it won't be too dependable, hopefully, I can get the D to the point it is!! Land Rovers remind me of the old saying about Jag's, you have to have two cause on is always in need of work! Your right Randy, just a few more $$ in the rover hole! Thanks again guys!
Old May 29th, 2006, 10:14 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Question Clutch master cylinder leaking...
Hello there...
New does not mean troubleless...
I've a leaking clutch master cylinder on a 2005 D90.
Not a big leak, a small drop each morning on the
front rubber carpet... so the question is:
Should i change the whole cylinder or the
repair kit will do the work properly ?
Any advice about this small repair ?
And finally, who sell this part in the US ?
(STC100410G for Lucas or STC100410 for
other brands, 550732G and 550732 in the
past).
- Charles Eames
Old May 30th, 2006, 12:09 AM
Is there no warranty service available for your truck?
The seal kit will probably do it, but why not order a new cyl and rebuild the old as a spare? They are cheap enough that its not really a financial choice.
RN can probably sell you the part, RDS probably has it in stock and won't f*ck up shipping to the DR.
Old May 30th, 2006, 09:13 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Well Jim, you probably will not believe this but the LR representative
here are so bad in any ways that i dropped a 3 years warranty on this
truck so i d'ont have to deal with those %^$%()&%$#!@ .....
I'll probably follow your advice, change the cylinder and rebuild the
other one.
Just a small question, RN is RoverNorth i presume, who is RDS ?
- Charles Eames
Old May 30th, 2006, 10:07 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
RDS is Rovers Down South... www.roversdownsouth.com
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old September 14th, 2006, 03:07 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Fluid under clutch pedal
I noticed some fluid under my clutch pedal. It is running down the back of the shaft of the pedal and dripping on the floor. Any thoughts on what it could be?
Old September 14th, 2006, 03:15 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Are you sure it isn't just water? You could have had something spill in your tray below the vents, or have a leaky vent seal.
Old September 14th, 2006, 03:16 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
clutch master cylinder leaking
3rd low and BOOT IT
Old September 14th, 2006, 03:19 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
It is not water, definitely lube or oil of some sort.
Jimmy, is the fix to replace the master cylinder?
Old September 14th, 2006, 03:22 PM
jimmy salmon
jimmy salmon
94 D90 AA Yellow
for the cost its not worth rebuiling, get the complete cylinder. bit of a bastard to do tho. i did mine not long ago. if you need a hand you could always bring your truck over and i'll help ya
3rd low and BOOT IT
Old September 14th, 2006, 03:28 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I replaced mine (bitch of a job to do) and also bought a kit to rebuild the old one. The bore was good so it really just needed a new seal. The rebuilt one is in a sealed plastic bag back in my Troys box where I'll always have a backup spare handy. These things always fail at the most inconvenient times.
Old September 14th, 2006, 03:29 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
See there,.....don't listen to me (the guy with the automatic) when it's a clutch question!
Old September 14th, 2006, 03:30 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
So am I buying the master cylinder clutch and reservoir?
Old September 14th, 2006, 03:31 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I keep having to replace my clutch master every year and a half or so. What gives??? I'm thinking its either the bushings on the pedal itself thats causing undue wear on the cylinder piston or mabye I didn't adjust that adjustment bolt right. Anyone else have that problem?
clutch, master, slave
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Brake Master Cylinder Leak chris snell Defender Technical Discussions 12 September 28th, 2011 09:50 AM
Defender Returns to North America Merged Threadfest rover1 Misc. Chit-Chat 495 May 12th, 2010 11:32 AM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
