Clutch master cylinder replacement - Page 2 - Defender Source
Old July 8th, 2015, 08:01 PM
Departing90
Sasha
95 D90
Its a pain if you've never done it before. After the 5th time or so you'll be replacing it in 20 min flat and that includes bleeding.
Ive personally never had good luck with any aftermarket mc. Even oem has been a pain. You'll see my point after you'll have to remove and replace 3x due to seal leaks. Unless the cylinder wall is pitted and I highky doubt that it is a washer and spring rebuild kit is only about $7- and easily changed.
When installed run a clear hose from the slave bleeder nipple straight into tye master cylinder reservoir and just keep pumping the clutch untill all bubbles are gone. No waisted fluid and no mess!
ac, clutch, master
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Clutch Master Cylinder Abrooks For Sale - Parts 4 December 2nd, 2009 11:18 AM
Re-Sleeve ing Rear Brake and Clutch Master Cylinder COSteve Defender Technical Discussions 12 June 24th, 2006 12:33 AM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
