Clutch Master Cylinder Adapter Too Long - Defender Source
Old February 22nd, 2014, 08:52 PM
98 HOO's Avatar
98 HOO
Josh Smith
1960 Series 2a/D90 Hybrid
I am replacing my clutch master cylinder - when I threaded in the hydraulic line adapter into the new MC, I found out it is too shallow for the length of the adapter. The threads are right, the adapter is just longer than the opening is deep.... I have several of the copper washers - If I stack 3, I can tighten it down - will this work? I went to multiple stores and couldn't find a shorter adapter... Thought about swapping the new guts into the old MC body, but after disassebling the old one, the bore is scored...
Thanks for the help.
Old February 22nd, 2014, 09:21 PM
I just went thru something like this a month ago. I sent all the aftermarket stuff back and paid big bucks for genuine Land Rover parts from Rovers North. Everything fit like it was supposed to.
Old March 4th, 2014, 04:48 PM
98 HOO's Avatar
98 HOO
Josh Smith
Just in case someone searches for this later - it worked fine with the three washers stacked. Been driving like that for several days without any sign of a leak.
clutch, master
clutch slave cylinder lordhelemt Defender Technical Discussions 4 May 9th, 2013 07:23 AM
Defender 90/110 Brake master cylinder brand new Shop On Broward For Sale - Parts 5 March 21st, 2013 05:22 PM
Early 90 Brake Master Cylinder - NRC9529 navydevildoc Wanted 3 February 5th, 2013 06:43 PM
Poor Brakes - Master Cylinder ? kzack Defender Technical Discussions 1 August 6th, 2012 12:36 AM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
