clutch line - Defender Source
Old March 24th, 2011, 10:10 PM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
clutch line
Has anyone used the Classic Tubing stainless clutch line? My line is leaking and I need to replace it. Do they have stainless fittings? Any other places to get them other than ECR?
Since I have gotten rid of most of the rust on the truck I am seriosly thinking of changing her name from Tetanus to Depends, because she leaks so much.
My Rover doesnít leak oil, she is marking her territory.
Old March 25th, 2011, 06:38 AM
TS888's Avatar
TS888
Tony Sims
1984 110
If this is the right thing, you can buy it direct
Classic Tube clutch line
From their FAQ:
9. Do stainless steel tubes come with stainless steel fittings?
In almost all cases we use stainless steel fittings, in some rare cases like transmission and carb lines the stainless steel fittings are an option.
OTOH, the OEM part lasts quite along time, and even in the US it's pretty cheap.
Tony
1984 110 "Smokey" (sold)
Old March 25th, 2011, 02:00 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I had one made locally. I removed the two rigid lines and had a flexible line made to run from the MC to SC.
Stainless and Birmabright don't play well together, so I'd be a little concerned about stainless fittings screwed in to Aluminum master and slave, especially with the already corrosive nature brake fluid.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 25th, 2011, 02:11 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
A little never-seize or ECK on the threads and you'll never have an issue with that fitting.
Classic Tube does sell all the products directly, same pricing. Down side is lead time and seeing if they made it right the first time.
Email:
Old March 25th, 2011, 09:56 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Yeah, I've always used Never-Seez on them, but a lot of people don't, for one reason or another.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 25th, 2011, 10:14 PM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
Thanks all I will order from Classic on Monday.
clutch
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
Extended Length Clutch rubber line? Antichrist Defender Technical Discussions 7 November 24th, 2006 11:40 AM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
