Clutch Kit Install Cost? - Defender Source
Old July 22nd, 2009, 08:50 AM
mikeybob2@msn.com's Avatar
mikeybob2@msn.com
Michael Sabanovich
1994 Defender 90 #1880
Question Clutch Kit Install Cost?
I think my clutch is about gone at 134,000 miles. The pedal is wanting to stay down and it's been pretty noisy since it got salt water logged last year.
I'm about to take it to my local shop but wondering about how much should I expect to pay? I see a LUK clutch kit on Ebay for $400+ but not sure what to expect for install?
I appreciate any advice.. Thanks
1994 D90 #1880
Old July 22nd, 2009, 08:57 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Michael, Before doing this you may want to check your clutch cylinders *master/slave. They may just need to be replaced. Had my pedal drop as well, it would come back up but drop again. After replacing both no issues.
Weldon
Old July 22nd, 2009, 09:52 AM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
Michael,
I had the same issues as well. Replaced the clutch cylinder and solved the problems.
Eric
Old July 22nd, 2009, 01:04 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Book price is around ten hours labour
3rd low and BOOT IT
Old July 22nd, 2009, 03:22 PM
Yes, check the hydraulics. A worn out clutch very just slip. It has nothing to do with the pedal.
Old July 22nd, 2009, 05:22 PM
Mike,
Make sure you have done this before doing anything expensive.
http://www.defendersource.com/forum/...ead.php?t=5808
http://www.defendersource.com/forum/...=clutch+spring
Ron
clutch, kit
200tdi install cost D90user Defender Technical Discussions 4 September 19th, 2006 04:21 PM
How To install Badger Gutter Kit ??? Help TDI Guy Defender Technical Discussions 4 November 5th, 2005 05:41 PM
Fan clutch install? Need instructions MiniGuy Defender Technical Discussions 4 March 5th, 2005 10:09 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
