Clutch kit - Defender Source
Old March 11th, 2013, 07:38 PM
Thatcher
Sean
1996/110/RHD
Clutch kit
Hey guys,
Brand new here. I believe I have to rebuild my clutch and am wondering the best place to get a clutch kit in North America. I am in Canada and looking for the best bang for my buck. I am new to this world as well, bought my 300tdi 110 just over a year ago and have been learning quick and rebui
Ding many parts.
Old March 11th, 2013, 07:44 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
Try Justin at Lucky 8.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old March 12th, 2013, 12:39 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Rovers Down South
- Charles Eames
Old March 23rd, 2013, 11:33 AM
Thatcher
Sean
1996/110/RHD
Thank you thank you
I have some options, I am wondering if anyone is familiar with Borg & Beck clutch components and GKN bearings?
What kind of rating should Lucky8 get? Honesty keeps us safer, there are a good amount of flakes out there and I would appreciate it.
Cheers
Old July 3rd, 2014, 09:53 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Pulling back this thread to ask: why do you have to systematically change your clutch cover when you change your clutch plate ? doesn't seem logical to me. That would be like changing your brake calipers when you're changing your brake pads.
Thoughts ?
Cheers
- Charles Eames
Old July 3rd, 2014, 09:58 AM
Because the clutch cover has two wear parts:
The spring used to press the clutch cover against the clutch disc
A smooth surface that engages the clutch disc providing additional gripping force.
Old July 3rd, 2014, 11:57 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Thoughts ?
Cheers
Well if you're like me then you weight the marginal cost of materials against the potential for failure shortly after. I mean the hours required to do the job in the first place will generally dictate whether or not you replace everything while you're in there.
Basically if you're in there you mind as well replace it. Its like doing brake pads without replacing the rotors. You can do it, but if there is even a thought in your mind that you will be back in there doing rotors in 90 days just replace the part.
Old July 3rd, 2014, 12:02 PM
Thoughts ?
Cheers
No. That would be like changing your rotors (or getting them machined) when changing the pads, which you should always do as well.
Old July 3rd, 2014, 12:15 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
jinx
Old July 3rd, 2014, 12:49 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
All right, I'm convinced enough, order placed on LRdirect.
- Charles Eames
clutch, kit
defender clutch kit... the rover shop For Sale - Parts 4 September 6th, 2012 04:00 PM
What clutch kit do I need? Jymmiejamz Defender Technical Discussions 6 May 9th, 2012 03:51 PM
Clutch Kit kzack For Sale - Parts 0 September 12th, 2010 10:26 AM
Clutch Kit Install Cost? mikeybob2@msn.com Defender Technical Discussions 5 July 22nd, 2009 05:22 PM
