clutch issue - Defender Source
Old July 14th, 2012, 06:30 PM
K9Phil
Phil
1994 D-90 #1184
clutch issue
Picked up my new (to me) D90 from the shop yesterday after having several upgrades and mods done, none of which had anything to do with the clutch, and the clutch seemed to be sticking a little. This morning, when I backed out of the garage and took my foot off the clutch, it stuck completely, fully depressed. I had to push it hard a couple of times to get it to release. I also noticed some fluid on the floor mat directly under the pedal. Not much, maybe 3 or 4 drops worth, that seems to have dripped from the clutch pedal. Drove it around for a couple of hrs and as soon as it warmed up, it seemed ok. Thoughts?
Old July 14th, 2012, 07:03 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Your slave or master cylinder needs to be replaced. Just a matter of time before I gives out.
Old July 14th, 2012, 07:21 PM
Irony is I've had to do the 90 last month, 88 is down as we speak with it out (same part # ironically), and I think the 110 needs it too. If you search for this you'll find all these horror stories of how "hard" it is. It's a piece of cake of you know how to bleed brakes or the clutch.
------ Follow up post added July 14th, 2012 07:24 PM ------
Here's a writeup I did:
http://www.defendersource.com/forum/...06&postcount=7
Old July 14th, 2012, 08:31 PM
K9Phil
Phil
1994 D-90 #1184
One of the things they did last week was install SS brake lines. Any chance of that having anything to do with this?
Old July 14th, 2012, 08:41 PM
Doubt it unless they loosened the clutch reservoir for some reason, but I doubt they'd do that on a LHD truck - access is not a problem.
clutch
200tdi / LT77 clutch issue kjva Defender Technical Discussions 11 May 29th, 2012 10:41 PM
weird clutch issue tomaco1 Defender Technical Discussions 4 August 6th, 2011 07:34 AM
Do I have a clutch issue ? Or is this something really bad paulb Defender Technical Discussions 3 October 18th, 2010 09:05 PM
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
