clutch help please - Defender Source
Old January 30th, 2012, 05:19 PM
huck1974's Avatar
huck1974
shane cates
94 d90
clutch help please
When cold, the clutch is fine. The longer it runs, the worse it slips. Put a new clutch in about 3000 miles ago. I replaced master and slave less than a year ago. After removing the tranny inspection cover, no oil in there.
Seems this started after the last deep water play time. I got busy with other projects and let it set in the garage for the last few months. I was going to pull the tranny again and take a look at things, but I figured I would ask you guys before I waste two days. Could be a slave sticking or something.
Thanks in advance
And hay
And I love you too
Old January 30th, 2012, 05:29 PM
Shane where've you been?!?!
Old January 30th, 2012, 05:31 PM
Naplm00
Matthew
Fluid getting hot and foaming up? could be water in the brake fluid?
Old January 30th, 2012, 06:11 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Could you have adjusted the Clutch master cylinder incorrectly?
legend in my own mind
Old January 30th, 2012, 06:21 PM
This. You need free play at the pedal or it pumps up and does not fully release.
Old January 30th, 2012, 08:15 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Will give this a shot tomorrow. Very possible I didn't get it right.
------ Follow up post added January 30th, 2012 07:24 PM ------
If there was a sarcasm button I could push after every one of my posts, that would make it better....
Really though, been working really hard and finishing other projects. Im also taking $100 bucks a week at 22% interest from people lacking teeth. Thats another story though. Hope things are well for you.
And hay
And I love you too
Old January 30th, 2012, 09:26 PM
Do you generally adjust the pedal distance from the floor per rave or do you do it by "feel"? Is this done by the rod on the nc inside of the box or the screw on the outside?
Old January 30th, 2012, 10:19 PM
I do it by feel but that is probably just "Ron good."
Old February 1st, 2012, 09:57 PM
huck1974's Avatar
huck1974
shane cates
94 d90
seems to be good now. thanks guys
And hay
And I love you too
Old February 2nd, 2012, 01:18 PM
Originally Posted by huck1974 View Post
seems to be [edit] Ron [edit] good now. thanks guys
Fixed it.
Old April 5th, 2012, 02:39 PM
Duxrover
Charlie Grace
1994 Defender 90
I have a similar issue with a clutch "slipping" when my 94 d-90 is warmed up. The clutch acts fine with it is cold. The slipping recently started after the master and slave were replaced. The clutch itself is not that old.
I am curious to know more about the adjustments that can be made as they seemed to solve this issue.
Thanks!
clutch
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
