Clutch fork - difference between V8 and TDI for R380? - Defender Source
Old September 8th, 2014, 03:07 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I was going to replace my worn clutch fork with a new one. I see these on eBay listed as "heavy duty" which have the reinforced tab on them.. but they say "NOT V8" on the ads.
http://www.ebay.com/itm/DEFENDER-CLU...28f07f&vxp=mtr
Is there really a difference between V8 and non-V8 R380? Why would it be listed as such?
Point to consider: I used my existing when I swapped in the 300TDI and I am pretty sure I used the existing clutch fork...
Old September 8th, 2014, 03:18 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
If you made that work, you must be magic...they are much different
------ Follow up post added September 8th, 2014 03:23 PM ------
I shot these to show the difference, the FTC2957 is Tdi and the 576137 is mostly all V8 engines, both for R380.
Old September 8th, 2014, 03:30 PM
If you put the 300TDI onto a V8 gearbox, you best fix THAT... The input shaft is the wrong length, the clutch spline engagement is wrong and the pilot bearing is not working.
Old September 8th, 2014, 06:28 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
It's been years ago I did this with a kit of parts provided by a guy in the UK. No magic - there was a different bell housing, pilot bearing, different clutch/pressure plate and a few other things involved - I just don't *remember* a different fork but this was many projects ago. It's been working great... maybe 4-5 years and 10s of K of miles.
clutch, r380, tdi, v8
Must replace R380 Fork - Do the clutch & rear seal too? Landspeed Defender Technical Discussions 3 May 25th, 2012 04:36 PM
Difference between TDi R380 and V8 R380? turbodave Defender Technical Discussions 5 July 19th, 2008 06:15 AM
LT230 - difference between auto and manual? jaherring Defender Technical Discussions 3 February 8th, 2008 11:17 PM
Difference between "WOLF" and "NATO" wheels? wicks Defender Technical Discussions 10 August 12th, 2005 04:23 PM
Help wanted: Difference between RR 2.5 TD and 2.5 DSE lakis Defender Technical Discussions 0 November 17th, 2004 10:23 AM
