Clutch Fork Clip - Defender Source
Old September 28th, 2014, 09:40 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Clutch Fork Clip
For an R380, if the clip that holds the throw-out bearing to the clutch fork is not installed, what will likely result? Thx. Mark
Old September 28th, 2014, 09:45 PM
my understanding is the clip is to hold things together while the trans is bolted up to the block. Once installed the clip isn't necessary. There is no way for things to come apart once the slave and its internal spring is pushing on the pushrod. I have broken them (the clips) and used rubberbands doubled up to serve the same purpose. Once all together the bands turn into dust pretty quickly.
Old September 28th, 2014, 10:24 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Thanks for the response, Doug. Had about 6K miles on a new standard clutch when the throw-out bearing failed. The nylon melted to the main shaft and the bearing seized. The clip in question was not used, so was wondering. I just put in a new R380 with a heavy duty clutch and made sure the clip was used. The all aluminum bearing won't melt like the last one. I guess a really hot clutch plate was the cause. Mark
Old September 28th, 2014, 10:58 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
All aluminum bearing?
Old September 28th, 2014, 11:14 PM
http://www.britpart.com/parts/repair...der/ftc5200hd/
Got mine from Justin, part# FTC5200HD...though haven't installed it yet.
------ Follow up post added September 28th, 2014 11:15 PM ------
Just curious, was there any symptoms leading up to the failure?
Old September 29th, 2014, 07:28 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Make a search using the clip's proper name "Death clip"
- Charles Eames
Old September 29th, 2014, 09:12 AM
Another option for throwout bearing is Megasquirt-V8. http://www.megasquirt-v8.co.uk/diff_offroad.php
Old September 29th, 2014, 12:14 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Truck is back together and hopefully won't have to deal with clutch/R380 issues for quite some time. Just seeing if anyone else had a similar issue and what was the cause. Either the clutch got really hot, melted the nylon, which cause the bearing to fail and seize, or the bearing was the source of the heat which caused the nylon to melt and the seizure.
Nathan - to your question. Holiday weekend traffic was heavy coming out of the mountains. On a long hill, traffic was stop and go up it, enough that I shifted into low range to make it easier on the clutch. 30 minutes later some light stop and go when the peddle felt odd, spongey, then froze up. I didn't hear any odd noises or feel any unusual vibrations before the clutch bearing went out.
Old September 29th, 2014, 12:54 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
clip is only there for assembly purposes. I just installed the all metal (HD) one from megasquirt-v8 in mine. Britpart also makes one.
also the clip is really pointless in a TDi as its installed upside down and will fall out instantly
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
clutch
Clutch fork - difference between V8 and TDI for R380? jaherring Defender Technical Discussions 3 September 8th, 2014 06:28 PM
Must replace R380 Fork - Do the clutch & rear seal too? Landspeed Defender Technical Discussions 3 May 25th, 2012 04:36 PM
Throw Out Bearing Fork bjf Defender Technical Discussions 13 January 29th, 2012 07:50 PM
Now stocking 300TDI HD clutch fork brn24whl The Vendors Loft 3 August 10th, 2011 05:57 PM
clutch release fork tomaco1 Defender Technical Discussions 0 December 18th, 2009 08:15 AM
