clutch for 95 d90 w/ 4.6 - Defender Source
Old January 2nd, 2006, 08:56 AM
vesparover's Avatar
vesparover
brian bertolini
Wink clutch for 95 d90 w/ 4.6
Hey everyone I just picked up a 4.6 for my defender. I figure while I'm in there I'll do the clutch. Where would I find the best deal on a complete clutch kit? I take it there is still no performance clutch available? Any other Ideas as to what should be taken care of when I have the motor out?
Brian Bertolini
Old January 2nd, 2006, 08:24 PM
Gardrover
James
95'
I've been thinking about converting to the 4.6 as well, but i keep on wondering about the clutch.
Are you carrying over your exhaust components? what are you going to use for the new ecu?
Sorry im not much help, good luck with your conversion.
Old January 3rd, 2006, 03:27 AM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
The stock clutch is fine. Unless you go with serious power I wouldn't worry about it. I replaced the clutch with stock with my 4.6 and it has been fine with no sign of fade. Unless you go with serious HP (300+) dont worry about a high performance clutch... Besides, I think you need a soft clutch for smooth take-offs. A real "High Performance / Racing" clutch will jerk the crap out of you. Could I burn out my clutch if I tried? I don't know... but don't let that hold you up on the conversion... Think about every cost. It is very expensive no matter how you look at it.
Old January 3rd, 2006, 08:18 AM
vesparover's Avatar
vesparover
brian bertolini
clutch
I'm re-using the 3.9 heads, so, I can reuse the exhaust system. Really the only thing you need is the 4.6 block, everything bolts right onto it from your 3.9. You can re-chip the ecu to work with the 4.6 as well.
-My clutch question is that I was looking on ebay, and they offer a couple brands for cheap. I'm looking to get a good clutch at a good price, after sinking so much money in everywhere else.
Old January 3rd, 2006, 08:40 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
You're right Brian, everything will swap right over. Don't forget that spacer/washer on the front of the crank that sets the pulley depth. Also, although I didn't have this problem, there can be a clearance issue with your oil pan. Using an oil pan gasket is supposed to take care of it.
I'm at about 3000 miles on my 4.6 and I just love it.
I got my clutch from George at RDS. I don't know if he's cheaper or not (or even open yet), but he sure is fun to talk to.
Old January 3rd, 2006, 10:02 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I always use genuine clutches. It is too much work to change to cheap out and save a few bucks.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old January 4th, 2006, 10:20 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I am still on my original clutch on my D90 and did the 4.6 swap maybe about 6000 miles ago or so and it has been fine. I have just under 90K miles on it, no slipping or anything. However, when I do replace my clutch, I am considering using a 110 clutch. But only considering it, because I cannot find fault with the D90 clutch. I still have to research that option a little more, but if I had to do a gut call swap without research, I would go with the standard D90 genuine clutch--I know it works and works well.
Old January 4th, 2006, 11:09 AM
Roadsiderob
Robert Dassler
1994 D90
I think all of the clutch kits supercede to one number now.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
90, 95, clutch, d90
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
94, AA Yellow D90 Zimbo76 For Sale - Vehicles 9 October 27th, 2004 10:39 AM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
