Clutch fluid capacity - Defender Source
Old March 16th, 2012, 03:12 PM
So getting ready to use the Motive bleeder on my clutch to flush the system with Castrol GT LMA Dot 4. Can't seem to find the capacity of the clutch system and don't want to overfill/waste LMA by filling up the Motive too much.
Anyone know how much the entire system calls for? I'm sure I could just go with 2 quarts and that would be plenty, but again don't want to waste any if I can avoid it.
While we're at it, planning on doing the brakes as well...but I think they're somewhere in the 2qt ballpark, correct?
Old March 16th, 2012, 03:39 PM
I'm not sure there is a downside to draining it first, but if you drain it you'll have a rough idea of what it will take to fill. I'd like to think it will flush it better by draining first (versus pushing the old out)
Originally Posted by pendy
I'm here for the D's
Old March 16th, 2012, 03:49 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Now we need Jeff and Tony to chime in to keep this theme going....
Old March 16th, 2012, 04:18 PM
Well, looks like the clutch capacity is about a quart. Already done! I think it took me longer to write on this thread than it did to flush the clutch using the Motive bleeder. This thing is awesome.
Next up - brakes!
Old March 16th, 2012, 09:38 PM
Next up - brakes!
Make that 0.5-0.75 quart for the clutch. Brakes were about 1.5qt total to full bleed each corner.
ac, clutch
clutch fluid ditskovich Defender Technical Discussions 17 February 1st, 2017 06:36 PM
dark grey clutch fluid? tomaco1 Defender Technical Discussions 8 February 19th, 2012 03:34 PM
Clutch Slave Master Fluid Mystery RickM Defender Technical Discussions 2 August 11th, 2010 06:19 PM
Mystery of the disappearing clutch fluid Trigger Defender Technical Discussions 4 January 5th, 2009 05:50 PM
