clutch flex hose - Defender Source
Old February 23rd, 2011, 09:27 PM
clutch flex hose
Has anyone found a stainless braided replacement?
Old February 23rd, 2011, 11:18 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I had a local shop make me one running from the MC to the SC.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 24th, 2011, 02:18 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
I've been meaning to do this, but I'm even more curious if anyone has fitted a remote-booster to the clutch. I'm assuming the kind used in some race vehicles would work fine and given the leg-pain I started developing after driving for 10h/day for a week I'm seriously considering it as an option.
Old February 24th, 2011, 02:34 PM
Goodridge do them for some apps, http://www.paddockspares.com/pp/DEFE...300TDI%29.html
Any decent hose place can make one up.
As to the clutch force, have you changed to the later style clutch box as they have reduced effort?
Old February 24th, 2011, 02:40 PM
ajh
Andrew J. Hutton
Yes, but I'm not 100% sure I have the spring setup correctly as the box came without it. If it is reduced then hitting it a few thousand times a day is still too much repetitive stress for my leg and hip to take. None of the other manuals I've owned have taken anywhere near the force.
Old February 24th, 2011, 02:59 PM
Not driven a truck before?
Have you driven another "stock" 300TDI clutch before to see if yours is wrong?
Old February 24th, 2011, 03:01 PM
ajh
Andrew J. Hutton
Not one with the assist spring, and either way the force is many many times higher than it has been on any other manual vehicle and there just isn't a reasonable excuse to put up with it when there's possibly a good solution.
Old February 24th, 2011, 03:48 PM
The spring on the pedal should not be adding any measurable resistance.
Old February 24th, 2011, 04:01 PM
ajh
Andrew J. Hutton
Got a close-up photo of how it's supposed to go on? I was pretty sure I got it correct by virtue of it only really fitting one way without serious personal harm being a possibility when fitting it.
Old February 24th, 2011, 04:09 PM
I can't see photos here at work... but I'm sure someone else can comment. I do know I changed the slave cylinder last week and without the clutch in the system pressing the pedal required very little force.
Old February 24th, 2011, 04:14 PM
The picture on this page is from the maintenance manual: http://www.autopartslib.com/search/d...2Bparts/page/4 See attachment for side view.
Old February 24th, 2011, 06:13 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Can't you just use stainless braided brake hoses???
clutch, flex
air intake hose --molded or flex jack SF Defender Technical Discussions 3 September 24th, 2010 12:30 PM
2 inch flex hose help MUDSUX Defender Technical Discussions 7 February 19th, 2010 09:16 AM
Soft hose from clutch master tomaco1 Defender Technical Discussions 4 December 1st, 2009 01:07 PM
Clutch Master, Slave & hose sale @ BP Neil McCauley Misc. Chit-Chat 0 September 22nd, 2006 07:11 PM
