Clutch fan nut on 97' 4.0 larger? - Defender Source
Old September 29th, 2006, 02:54 AM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Hi all. I did a search on clutch fan removal and I found lots of good info but I ran into a hitch. On my 97 4.0 the nut is larger than 32mm. On my 110 and 94' D90 the 32mm fits fine on those fan clutch nuts just not on my 97. I tried the BFH and screw driver technique and to no avail except for one scratched up nut. (Worked on my 94' fine) I think on this one I'll have to use the tool? British Pacific told me all years use the same water pump / fan clutch but the one on my 97 is obviously different. Should I buy the tool or find a larger crescent wrench? Thanks for the help!
Neil
Old September 29th, 2006, 04:16 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Yes, from previous research the threading and nut size on the '97 clutch fan IS larger than a 94-95 truck with V-belts. It also turns the other direction as well.
-Hans
My oil line fix
My 100k stopped odometer fix
Old September 29th, 2006, 06:34 PM
Neil McCauley
Neil McCauley
Red face
hehe, yeah I learned the hard way. The nut on the 97' IS bigger. I borrowed the tool from a shop in San Marino. Luckily I did, I gotta get me one of those wrenches. Reason is even after you take it off, you still have to tighten the nut. I'd rather use the wrench rather than tear up the nut when tightening it down. So the clutch fan on the 97' D90 is a lot different AND the thread does come off counter clockwise, unlike the 93 110, 94 & 95 D90.
Neil
97, clutch, fan
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Upgraded Fan clutch part numbers for 4.0 btate Defender Technical Discussions 2 September 28th, 2009 05:21 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
