Clutch fan help needed - Defender Source
Old March 27th, 2007, 05:14 PM
RoverC
Cliff
1997 D90 ST
Will a clutch and fan blades from a '97 D90 bolt up to a '95 D90?
I know the blade and clutch part numbers are different, but wonder if it will work as a simple replacement?
thanks
Old March 27th, 2007, 06:02 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
No a 1995 threads on with LH threads and the 1997 has RH threads. they are different.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old March 27th, 2007, 06:38 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
It will work if you tack weld it on!
Robert Deniro
Old March 27th, 2007, 07:21 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Well there's always that
Eric
Eric Riston
Old March 30th, 2007, 03:37 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
That'll make it alot of fun when it comes time to replace the water pump.
clutch, fan
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
Fiberglass Hard Top, Fan Clutch and Front QT Diff Guard cgalpin For Sale - Parts 10 January 6th, 2006 10:45 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
